udf fluent
Old   September 19, 2015, 09:12
Default udf fluent
golriz
gzamiri@gmail.com is on a distinguished road
dear all
I have written a program and compile it in fluent but getting the errors while building in fluent.
the program looks like this. please help me.
/* UDF for determination of inlet and outlet */
#include "udf.h"
#include "sg.h"
DEFINE_EXECUTE_AT_END(determination_boun)
Domain *d;
face_t f;
Thread *t;
real velocity_vector[2], mag_velocity, normal_vec, mag_normal_vec;
real A[ND_ND], ds, es[ND_ND], A_by_es, dr0[ND_ND];
real X_component,Y_component, Guage_Pressure;
d=Get_Domain(1);
int ID=12; /*Zone ID for farfield zone from boundary condition task page*/
t=Lookup_Thread(d,ID);
begin_f_loop(f,t)
/* find velocities*/
velocity_vector[0]=F_U(f,t);
velocity_vector[1]=F_V(f,t);
/* magnitude of velocity vector*/
mag_velocity=NV_MAG(velocity_vector);
/* magnitude of normal vector*/
BOUNDARY_FACE_GEOMETRY(f,t,A,ds,es,A_by_es,dr0);
mag_normal_vec=NV_MAG(A);
/* attack angle*/
double teta=0;
if((mag_velocity* mag_normal_vec*cos(teta))<0)
/*inlet boundary*/
X_component=F_U(f,t);
Y_component=F_V(f,t);
else
Guage_Pressure=F_P(f,t); /*outlet boundary*/
end_f_loop(f,t)
1 file(s) copied.
1 file(s) copied.
(system "copy "c:\PROGRA~1\ANSYSI~1\v121\fluent"\fluent12.1.2\sr c\makefile_nt.udf libudf\win64\2ddp\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\2ddp")()
# Generating ud_io1.h
determination_boun.c
c:\program files\ansys inc\v121\fluent\fluent12.1.2\src\config.h(110) : error C2143: syntax error : missing '{' before ':'
c:\program files\ansys inc\v121\fluent\fluent12.1.2\src\config.h(110) : error C2059: syntax error : ':'
Done.
gzamiri@gmail.com is offline   Reply With Quote
Old   September 19, 2015, 15:14
Bruno Machado
Bruno Machado is on a distinguished road
can you highlight which lines belongs these errors?
Bruno Machado is offline   Reply With Quote
Old   September 20, 2015, 04:08
golriz
there isn't this number line in my code
Old   September 20, 2015, 06:23
Bruno Machado
the error says the problem is in the line 110. This piece of code does not have this much lines, so check which line in your code is the 110th. can't help much with the information you provided so far.
Old   September 22, 2015, 04:50
pakk will become famous soon enough
The compiler complains about line 110 of a different file, not the file that gzamiri is showing.
In my copy of Fluent 12.1.4, lines 109-111 of config.h are:
#if !(RP_2D || RP_3D)
 Error: both RP_2D and RP_3D are undefined
#endif
So, if this is the same in Fluent 12.1.2, it looks like Fluent does not know if it is in 2D or 3D. For me it is clear that you want to do it in 2D. This is very strange for me.
The problem is probably not in your UDF code, but in your system settings. Are you able to compile other UDFs? (From the manual?)
pakk is offline   Reply With Quote
Old   September 22, 2015, 11:25
golriz
dear pakk
do you think that this error is for version of fluent?
Old   September 23, 2015, 13:26
golriz
I want to do my udf in 2D dimention.how can i specify it in my udf.
Old   September 23, 2015, 21:12
Meng Liu
sola86 is on a distinguished road
1.add the path of “config.h” to the system environment “include”.
2.you need declare the variable before you use it.
#include "udf.h"
#include "sg.h"
	Domain *d;
	face_t f;
	Thread *t;
	int ID;
	double teta;
	d=Get_Domain(1);
	begin_f_loop(f,t)
		/* attack angle*/
		teta=0;
			/*inlet boundary*/
		else
	end_f_loop(f,t)
sola86 is offline   Reply With Quote
Old   September 24, 2015, 01:54
golriz
dear sola
shoud I add config.h in my udf as follow?
#include "config.h"
Old   September 24, 2015, 02:37
Meng Liu
dear sola
#include "config.h"
no,just add the path to the system environment "include".
Old   September 24, 2015, 05:36
golriz
dear sola
I don't know how can i add the path to the system environment "include"
please help me
Old   September 27, 2015, 20:53
Meng Liu
dear sola
please help me
google “Environment variable”
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
Wind turbine rotation through UDF in FLUENT Shamoon Jamshed Fluent UDF and Scheme Programming 10 June 25, 2018 12:58
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 13, 2017 23:23
Making wave udf in fluent sunggun1212 Fluent UDF and Scheme Programming 7 October 27, 2015 10:52
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 10:57
