March 1, 2010, 05:10 |
How can I break a fluent calculation?
Herman
Hi, I'm simulating an unsteady flow, and I impose some time steps to FLUENT "a priori"; however my goal is to break FLUENT calculation "a posteriori", under some bond.
So my idea is to to write a UDF that under some bond impose to FLUENT to break the calculation, even if I impose "a priori" the number of time steps, but FLUENT can't read the command "exit" in my UDF. Can you help me? Thanks in advance. |
March 1, 2010, 10:28 |
Robert
Hi
Did you try the touch-command? http://willem.engen.nl/uni/fluent/do...ips-Tricks.pdf read page 9/10 for further informations I didnt try it, but maybe it helps. Greetings |
March 1, 2010, 10:51 |
Herman
Hi, thanks for your reply.
Maybe it can be useful. Last edited by enry; March 17, 2010 at 09:10. |
March 5, 2010, 03:22 |
See section 3.7 Input/Output Macros in UDF manual. It might help...
good luck |
March 5, 2010, 04:17 |
Herman
Thanks!
enry |
April 5, 2010, 19:18 |
Robert
Hi
Did you find a solution to the problem? |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
power and pumping number calculation in "FLUENT" | HARI SANKAR | FLUENT | 1 | March 29, 2011 16:20 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
Fluent Cd calculation | liflu | FLUENT | 0 | October 31, 2009 10:03 |
