Plasma Flow Modelling using Source term and cell's data
Old   March 11, 2010, 14:19
Lightbulb Plasma Flow Modelling using Source term and cell's data
C.K.
Constantine is on a distinguished road
Hello all,
I am trying to model the interaction of a normal flow and the flow that is produced due to a plasma actuator on a flat plate. I have the data of the plasma region from a matlab file which are my source terms , and using the datagrid command i created a grid of 30000(150x200) cells representing the plasma area.Then I created my mesh of the flat plate in gambit where I also created a similar grid of 30000 cells with the same dimensions of course in a x-position on the plate.So now the problem is how can I (using a UDF ) tell fluent that i want every cell data that i have to be 'patched' on the specific cells on my plasma region! I can create program that will read the txt data file from matlab in an array for example but how can i match the cell's data from the matlab's grid with the right cells in fluent?????
If i havent been clear enough , I am here for any further explanation!!
Any help is more than welcome!!!!
Constantine is offline   Reply With Quote
Old   May 10, 2010, 04:49
Mominul MuKuT
mukut is on a distinguished road
Both of our working field is same. I also try to simulation flow induced by plasma actuator in phoenics. If we can communicate more with each other I think we can do good. If so please mail me.
mukut is offline   Reply With Quote
Old   May 19, 2010, 21:06
Hongjin Wang
sosososo1114 is on a distinguished road
Can your matlab programm export the coordinations of the cell centrode? If it is, I think you can just ask your matlab programme write a fluent profile file that contains every value u want as well as the coordiation of cells. And then u can write a journal file to ask the FLUENT to read them from the profile file and to set your BCs
I hope it is useful
Have a good day
Regards
Hongjin Wang
sosososo1114 is offline   Reply With Quote
cell, data, plasma, source, udf
UDF Source Term Christian FLUENT 4 August 1, 2009 05:53
Define a source term Chen Fangzhi FLUENT 0 July 2, 2003 07:41
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 12:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
