entropy generation with UDF
Like Tree2Likes
Old   May 7, 2010, 06:25
Default entropy generation with UDF
mohammad
mohammadkm is on a distinguished road
Dear all
I want to compute entropy generation in tube with constant heat flux.
I wrote a udf to compute gradient temperature:
# include "udf.h"
# include "math.h"
DEFINE_ADJUST(adjust_gradient, domain)
Thread *t;
cell_t c;
face_t f;
domain = Get_Domain(1);
/* Fill UDS with the variable. */
thread_loop_c (t,domain)
begin_c_loop (c,t)
C_UDSI(c,t,0) = C_T(c,t);
end_c_loop (c,t)
thread_loop_f (t,domain)
if (THREAD_STORAGE(t,SV_UDS_I(0))!=NULL)
begin_f_loop (f,t)
F_UDSI(f,t,0) = F_T(f,t);
end_f_loop (f,t)
DEFINE_ON_DEMAND(store_gradient)
Domain *domain;
cell_t c;
Thread *t;
domain=Get_Domain(1);
/* Fill the UDM with magnitude of gradient. */
begin_c_loop (c,t)
C_UDMI(c,t,0) =(pow(NV_MAG(C_UDSI_G(c,t,0)),2));
end_c_loop (c,t)
after the iteration in custom field function, i defined:
dissip=(2 * ((daxial-velocity-dx) ^ 2)) + ((daxial-velocity-dy) ^ 2)
S(generation)=((thermal-conductivity-lam * udm-0) / temperature ^ 2) + ((viscosity-lam * dissip) / temperature)
with this way i compute entropy generation in fluent.I can compile my code and get answer without any problem but my result is wrong(not validated with paper). I think my code for compute gradient temperature is incomplete and i need to compute gradient temperature in face too, but i dont know how can i do that?
please help with this problem
thanks
mohammadkm is offline   Reply With Quote
Old   May 7, 2010, 07:32
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
I think you can easyly skip all the troubles by directly using the temperature gradient provided by fluent?
However, to be able to access gradients you need to tell fluent to store them (check the udf manual section 3.2.3 - solve/set/expert).
A suggestion:
instead of
you could use
C_UDMI(c,t,0) =NV_MAG2(C_UDSI_G(c,t,0));
dmoroian is offline   Reply With Quote
Old   May 7, 2010, 12:43
mohammad
Dear dragos
How can i directly use gradient temperature provided with fluent? there was no gradient temperature(dT/dx) in custom field function panel to use!!
I did that(solve/set/expert) but my result was not changed.
I tried this code to compute gradient face temperature:
# include "udf.h"
# include "math.h"
Thread *t;
cell_t c;
face_t f;
begin_c_loop (c,t)
end_c_loop (c,t)
begin_f_loop (f,t)
end_f_loop (f,t)
Domain *domain;
cell_t c;
Thread *t;
face_t f;
begin_c_loop (c,t)
end_c_loop (c,t)
thread_loop_f(t, domain)
begin_f_loop(f,t)
F_UDMI(f,t,0) =(pow(NV_MAG(F_UDSI_G(f,t,0)),2));
end_f_loop(f, t)
but i got this error:
..\..\src\test.c(48) : error C2109: subscript requires array or pointer type
please help me i don't know how to solve my problem. i am reletively new to UDF.
thanks
Old   May 8, 2010, 04:19
dmoroian's Avatar
Dragos
It seems either I missunderstood again your problem, or you mixed up concepts.
To clarify: if you need temperature gradient only as a field function, then you don't need udf's. To get the temperature gradient available in field function you have to tell fluent to store it after each iteration (presuming that you have enabled the energy equation first). If you had red the manual page I suggested, you would have found, that storing the gradients is straight forward:
/solve/set/expert
Keep temporary solver memory from being freed? [no] yes
After at least 1 iteration you will see three new fields in the derivatives of the field function: dT-dX, dT-dY, and dT-dZ
Old   May 9, 2010, 17:12
mohammad
Dear dragos
you solved my problem, thank for your help.
As you said there is no need to write udf, i just used "/solve/set/expert".
After that i changed criteria of energy from 1e-6 to 1e-12 and my solution was validated.
thanks again
Old   March 12, 2013, 07:14
Satish Gupta
Rahul123 is on a distinguished road
I am solving a 2D problem. I want to write the value of temperature gradient on a surface (I need the values). Can anyone tell me how to do it......I think a udf is to be written but I dont understand which macro to use. I have the end point coordinates of the surface(line)
Rahul123 is offline   Reply With Quote
Old   March 12, 2013, 09:39
mohammad
you don't need to write udf for calculating the gradient. you should just keed the data by typing a command in the console. I can't remember the command but you can find it in the UDF PDF file.
Old   March 12, 2013, 12:41
Satish Gupta
I want the gradient value on a wall i.e, surface.....will it be possible
Old   March 14, 2013, 15:35
mohammad
I think it is possible. And the command to keep the memory is :
/solve/set/expert
good luck
Old   February 13, 2014, 12:50
Satish Gupta
hi,
could you please write the custom field function for entropy generation
Old   February 24, 2014, 14:20
mohammad
Dear Rahul,
Custom field function can be written based on the formula that I have attached in the first post. For adding gradient temperature you need to type the following statement in the cosole:
/solve/set/expert...Keep temporary solver memory from being freed? [no] yes...Good luck
Old   August 30, 2014, 13:03
Default Regarding Entropy generation
  #12
Ashok
ashok_iit@hotmail.com is on a distinguished road
I tried to calculate the entropy generation using the command: solve/set/expert
Now, I got the reconstructed dT-dx, dT-dy and dT-dz.
Can these values directly be used in my custom Field function to compute entropy.
Can any one help me out
mail me: ashok_iit@hotmail.com
ashok_iit@hotmail.com is offline   Reply With Quote
Old   September 12, 2014, 13:18
Default how i enter attached equation in custom filed function?
  #13
Abdul Sattar Dogonchi
setty is on a distinguished road
Originally Posted by mohammadkm View Post
Dear Rahul,
Hi mohammad
how i enter equation that you attached in custom filed function?
please help me about this
thnx
setty is offline   Reply With Quote
Old   July 11, 2015, 12:29
Default entropy generation custom field function
  #14
Rasoul
Ras0ul is on a distinguished road
Dear all
I entered the entropy generation equation in custom field function.but my result is wrong(not validated with paper). I examined my results and found that Fluent calculate the temperature gradient, but it can not properly calculate the square of the temperature gradient!!!
thanks
Ras0ul is offline   Reply With Quote
Old   July 14, 2015, 10:05
pakk will become famous soon enough
There are two options:
- Fluent has a bug and calculates the square of the gradient of temperature wrong.
- You did something wrong when you tried to let Fluent calculate the square of the gradient of the temperature.
You seem to think that the second option is very unlikely. I think the first option is very unlikely.
pakk is offline   Reply With Quote
Old   July 14, 2015, 10:58
Rasoul
Dear pakk
of course, i think the first option is very unlikely. But I really do not know what's the problem. For a specific position within the computational domain, when i account the entropy based on the components separately, there is difference between the answer with custom field printing result. Interestingly, this difference can be seen when i want to calculate the square of the temperature gradient !
Old   July 14, 2015, 11:16
So you agree that it is possible that you did something wrong when you tried to calculate the square of the temperature gradient, but you don't know what it is you could have done wrong.
And what now? I think it is impossible to get help on which of your steps could be wrong, if you don't say which steps you took. But that is just my opinion.
Old   February 26, 2016, 05:52
Post fluid friction of volumetric entropy generation rate
  #18
Altayyeb kinhar
A. Kinhar is on a distinguished road
Good day All: i have problem with the fluid friction of volumetric entropy generation rate, i already used the steps of Solve/set/expert
and i get the heat transfer of entropy generation with the accepted results but i have problem with the friction of entropy generation
The results of the friction are so low its around 0.0000029 when the Reynolds number is 100 and the heat flux is 100 000 w
I used this formula in the Custom field function to get the fluid friction ( Viscosity * strain rate^2/static temperature)
will you help me to know why the results are so low .... thanks and kind regards
A. Kinhar is offline   Reply With Quote
Old   February 26, 2016, 09:14
Default I'll posed problem
  #19
dmoroian's Avatar
Dragos
Hello Kinhar,
I cannot answer your question because your problem is not very well described, and I am not knowledgeable enough to guess it.
Old   October 13, 2017, 15:06
Default Entropy generated FLUENT
  #20
madan
madhan is on a distinguished road
Hi.
I have tried using this custom field functions for calculating entropy for 3d conjugated problem. but my values are so high. Could anybody tell me is there any other ways to calculate entropy generated due to heat transfer and viscous dissipation.
There is no clear sources available online for calculating entropy. If anyone could post the procedure it will be helpful for learners like me.
Thanks in advance.
madhan is offline   Reply With Quote
UDF - volumetric heat generation Thiago Castro Fluent UDF and Scheme Programming 1 April 5, 2019 02:15
Entropy Generation in compressible flow Dave FLUENT 0 January 5, 2004 07:12
Latest News in Mesh Generation Robert Schneiders Main CFD Forum 1 February 18, 2000 00:48
Latest new in mesh generation Robert Schneiders Main CFD Forum 0 February 16, 2000 07:12
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
