I find the solution of mesh dynamic
Old   June 8, 2010, 20:24
Cool I find the solution of mesh dynamic
alliche redha
cheredha is on a distinguished road
http://www.cfd-online.com/Forums/flu...ique-mesh.html
have found the solution , But I do not understand
okie I guess there might be two reasns behind it: 1. U have not set the path. 2. U are not compiling from the correct directory. U have to compile inside the libudf>src>2d/dp/3d/dp from there copy the path and change it. Go to the command prompt, copy the path, by cd ...and then give nmake. Podila
here is the page where I can find the solution, is the same problem as me
http://www.cfd-online.com/Forums/flu...h-problem.html
cheredha is offline   Reply With Quote
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Dynamic Mesh with Boundary Layer Marcell FLUENT 0 March 11, 2009 08:40
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
dynamic mesh ads FLUENT 5 January 26, 2005 04:27
Help: Is it possible to use dynamic mesh model and Valery Ponyavin FLUENT 1 September 20, 2003 14:18
