tagging of single nodes.
Old   August 11, 2010, 10:57
Default tagging of single nodes.
chaos is on a distinguished road
hello!
at the moment i am working on an fsi in fluent.
finally it was not so hard to programm an fsi for struktural simulation. (for only one part).
but now i need to split my part... (for different material id's)
my solution was to compare (at the first fsi loop) the external grid koordinates with the internal node koordinates of fluent.
so fluent makes a loop over all shell node and if the koordinates match it stores the external nodenumber into NODE_MARK(v).
after that i can work with nodemark and easily write the needed informations for the external program into a file.
but after the first fsi loop some of the NODE_MARK(v) values have changed!
is there a way to get the internal nodenumber of fluent?
then i could make a table between the fluentnodenumbers and the external nodenumbers.
i'm not shure but is NODE_MARK(v) the global nodenumber of fluent?
Yours sincerely
steven
sorry for my bad english
chaos is offline   Reply With Quote
Dual Nodes is Slower Than Single Node (Reposting) Mrxlazuardin Hardware 1 May 26, 2010 10:25
Dual Nodes is Slower Than Single Node Mrxlazuardin FLUENT 0 May 21, 2010 01:48
Scale-Up Study in Parallel Processing with OpenFoam sahm OpenFOAM 10 April 26, 2010 17:37
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
