How to calculate velocity at a interior surface?
Like Tree2Likes
  • 2 Post By wanghaojie
Old   March 23, 2012, 10:21
Default How to calculate velocity at a interior surface?
HJ
wanghaojie is on a distinguished road
Im trying to get the velocity at a certain surface by udf.
First I try to use
F_U(f,t)
but when it runs, the fluent will stop and say there is an error. I further examined it and found out it can only be used for boundary surface
Then i try to calculate the surface velocity by averaging the cells before and after the surface. Then i can get results but it is different from the contour result. I think the contour results is calculated by staggered grid? So how can i get exactly the same results as in the contour by udf?
Thanks
bawangdian and JamesCC like this.
wanghaojie is offline   Reply With Quote
How to calculate the gradient of pressure and velocity diegosene OpenFOAM 2 September 28, 2011 09:03
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
calculate the average velocity of particles robert FLUENT 0 August 1, 2008 09:44
how to calculate a scale velocity in vectors ladypowel FLUENT 0 May 8, 2007 18:40
Velocity Under-relaxation in SIMPLE type methods Matt U. Main CFD Forum 6 July 4, 2005 05:29
