UDF Output zero?
Old   March 23, 2012, 10:00
Default UDF Output zero?
HJ
wanghaojie is on a distinguished road
Hi all,
I try to save the flow rate on a plane and velocity at another plane here is the udf I used. But the flow rate on the plane output is zero and i further check the velocity on the plane is also zero
Can you guys help me check what the problem is?
I think the thread id is correct.
Can it be the numerical type problem?
#include "udf.h"
#define ID1 10036 /*Window ID*/
#define ID2 10028 /*Horizontal Plane ID*/
DEFINE_EXECUTE_AT_END(SaveData)
Domain *d;
FILE *fp;
face_t f;
real A[2];
real x[ND_ND],z;
Thread *t,*t0,*t1;
real incid;
real u=0,v=0,v_door=0,VentRate=0,time=0;
cell_t c0, c1;
/*Ventilation Rate*/
fp = fopen("VentRate.csv","a+");
d = Get_Domain(1);
t = Lookup_Thread (d, ID1);
begin_f_loop(f, t)
F_AREA(A,f,t);
c0 = F_C0(f,t);
t0 = THREAD_T0(t);
c1 = F_C1(f,t); /* Get cell on other side of face */
t1 = THREAD_T1(t);
v_door= 0.5*(C_V(c0,t0)+C_V(c1,t1));/*Average the velocity before and after the door)*/
VentRate=0.5*fabs(A[1]*v_door)+VentRate;
printf ("%f\n",time, v_door);
fprintf (fp, "%f\n",time, v_door);
end_f_loop(f, t)
time=CURRENT_TIME;
fprintf (fp, "%f,%f\n",time, VentRate);
fclose(fp);
/*Horizontal Velocity*/
fp = fopen("H.csv","a+");
time=CURRENT_TIME;
fprintf (fp, "%f\n",time);
d = Get_Domain(1);
t = Lookup_Thread (d, ID2);
begin_f_loop(f, t)
F_CENTROID(x,f,t);
c0 = F_C0(f,t);
t0 = THREAD_T0(t);
t1 = THREAD_T1(t);
u= 0.5*(C_U(c0,t0)+C_U(c1,t1));
v= 0.5*(C_V(c0,t0)+C_V(c1,t1));
t0 = THREAD_T0(t);
t1 = THREAD_T1(t);
fprintf (fp, "%f,%f,%f,%f,%f\n",x[0],x[1],x[2],u,v);
end_f_loop(f, t)
wanghaojie is offline   Reply With Quote
Old   March 23, 2012, 10:03
HJ
Also, I think the fprintf in the loop function wont work at all. I cannot get anything in the output file, but fprintf outside the loop function can give an output...
Old   March 23, 2012, 10:27
HJ
So now after i changed %f to %g, i am able to use printf and get real results in the fluent, but still cant use fprintf to save the data
UDF with output text file manu Fluent UDF and Scheme Programming 18 December 12, 2018 22:46
UDF unit and FLUENT output saifulraju FLUENT 4 September 21, 2010 22:22
Help with DPM UDF for OUTPUT needed Zhengcai Ye FLUENT 0 January 5, 2004 16:58
udf to output velocity at some point Jun FLUENT 4 August 19, 2003 13:43
UDF to output the modeling? Fluent Newbee FLUENT 4 August 22, 2001 03:45
