Simple data export question
Old   March 27, 2012, 12:56
Default Simple data export question
David Russ
mlbontbs87 is on a distinguished road
I am completely new to UDF programming, or to C in general, so hopefully this question will be easy for someone more experienced.
I am trying to export the following data for each cell in my domain:
x,y,z position, u,v,w velocities, and a list of which cells border that cell.
Ansys told me I can use the F_C0 & C_C1 macros nested inside a c_face_loop macro to generate a list of the bordering cells. I inferred that I need to nest that in a loop across all cells.
I think exporting the position and velocity data should be easier.
With that all said, I am not sure how to incorporate any of this code into a udf macro. Does anyone know an easy way to do this, or at least a quick way to learn UDFs for Fluent?
mlbontbs87 is offline   Reply With Quote
beginner, export, loop
Writing/output of simple data into an ASCII-File matthi OpenFOAM Programming & Development 24 January 8, 2019 13:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
Simple Question - or not? Florian2 Main CFD Forum 10 November 17, 2011 16:48
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
