April 18, 2012, 09:35 |
Extracting Coefficients of lift and drag
Jake Billingham
Hey everyone,
I'm very new to using FLUENT and as a final year project at university I'm studying how well CFD can emulate the ground effect on a simple NACA0012 with varying angles of attack and ride height. When setting up the case and data in fluent I've set the Cl and Cd to print to console but I've got no idea how to get them back out, can anyone help me with this? Thanks, Jake |
April 19, 2012, 01:10 |
Lucky
Rep Power: 66 |
Jake,
Use the write option. It is accessible in the GUI options where you setup the drag and lift monitors, just underneath the print and plot options. It will write the results to a text file after each iteration. You might need to give the file name a .txt ending so help windows recognize the file extension.. If you don't have GUI, it should have been prompted on the TUI when you setup the the monitors. |
April 19, 2012, 04:21 |
Jake Billingham
Thanks, I'll give this a try!
lift and drag coefficients around a ground vehicle | Pedro | CFX | 3 | September 5, 2012 18:31 |
Great lift coefficients but negative drag coefficient?! | nez | FLUENT | 0 | November 28, 2011 13:57 |
Calculation of lift and drag coefficients | Prachi | CFX | 3 | August 14, 2007 14:05 |
Lift and Drag Coefficients Reliability | Luis | FLUENT | 2 | December 27, 2005 14:45 |
pressure. lift and drag coefficients | waqar mahboob | Main CFD Forum | 0 | July 25, 1998 03:34 |
