Size-change
Old   April 23, 2012, 05:44
Default Size-change
Marco
ReeKo is on a distinguished road
Dear all,
I would like to hear your opinion about size-change mesh quality using TGrid in hybrid (prisms+tet) meshes for external/internal aerodynamics problems. It has, of course, a certain impact on the convergence behaviour of the solution.
In particular, what maximum size-change value would you rate to be OK for your simulations? The problem is very likely to happen when transitioning from prisms to tets.
Regards,
R.
ReeKo is offline   Reply With Quote
How to change turbulence model in InterFoam Gildeh OpenFOAM Running, Solving & CFD 4 March 28, 2012 12:04
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
