April 22, 2012, 13:23 |
High skin friction coefficient,
Rep Power: 14 |
Hello all,
I tried to do the tutorial of the cornell website for the turbulent flow, with the pipe dimenstion 8mX0.1m. and the inlet velocity of 1 m/s. choosing k-epsilon turbulence flow. but choosing material as water ( density-1000 kg/m3, and viscosity 0.0007 pa.s). I tried to make the mesh fine, to have low yplus ( I obtained yplus about 0.3 for fully developerd flow). but i wonder why the skin friction coefficient is 3.5 while in the moody diagram the maximum value is 0.1? why my result doesn't match with moody diagram. i attached the skin friction plot here. thanks skin friction.jpg |
April 22, 2012, 14:46 |
Lucky
Rep Power: 66 |
Did you remember to set your reference values? A reference velocity is used to calculate the skin friction coefficient. Not sure what the default in Fluent is. You should set it your bulk velocity (average cross sectional velocity) I believe. Also check to make sure the reference density is correct.
April 22, 2012, 18:13 |
Rep Power: 14 |
Aaaahh!! you are right!!! thank you sooo much for the response, I put many times and trying different meshes!! now i tried to put reference values and it seems it's ok. thanks again
skin friction coefficient, turbulence |
Skin Friction Coefficient | FrenchyTim | FLUENT | 10 | January 15, 2018 10:41 |
Macro for skin friction and pressure coefficient | DoHander | Fluent UDF and Scheme Programming | 0 | January 9, 2010 10:18 |
[OpenFOAM] Plot skin friction coefficient on a airfoil | dinonettis | ParaView | 3 | April 23, 2009 07:24 |
Compute Skin friction coef by hand | Francois | FLUENT | 1 | February 10, 2006 06:21 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
