May 4, 2012, 12:23 |
Porous Jump
Daniel
Rep Power: 14 |
I am having some difficulty understanding the porous jump in 2D - at least the porous jump is what I believe I need...I am trying to simulate flow through a wind tunnel test section which has a partially inserted wire screen in it. I am at the moment simplifying to a 2D model, so I have something that looks like this (see attached scrnshot, flow right to left).
My problem is also with meshing and specifiying the BCs...I tried modelling the screen as a very thin face (so i gave it a thickness in Gambit of 1mm - that red line at the lower gith corner of the image is actually the thin face) -here I had problems when meshing, the faces were not connected properly, I also then tried connecting them, but failed aswell...I did this after reading another comment here that in 2D, it would be an idea to create the both sides (across which a porous jump exists) and then set the boundary condition to just one face... Does anyone have experience modelling a similar feature ? I feel I am missing out on a rly simple fix and idea...Can anyone enlighten? Thanks alot!! |
fluent, porous jump, screen, wind tunnel |
[ICEM] How can I define different zones in ICEM? | llrr | ANSYS Meshing & Geometry | 14 | February 12, 2017 13:44 |
[Commercial meshers] Porous Jump creation problem | mulfal | OpenFOAM Meshing & Mesh Conversion | 4 | December 9, 2013 11:59 |
Porous jump in urban environment | samygero | FLUENT | 0 | February 14, 2011 18:26 |
Porous Jump | Naresh | FLUENT | 0 | April 25, 2007 15:36 |
Testing the integrity of POROUS media and por jump | Azman | FLUENT | 0 | July 31, 2006 11:11 |
