March 1, 2013, 05:39 |
Fluent Adjoint Solver Convergence Issue?
Malik
Rep Power: 13 |
Hello Everyone!
Case: Optimisation of front wing of a formula one car using Fluent Adjoint Flow Solver Issue found: With the conventional flow solver the residuals tend to converge within 350 iterations using k-epsilon turbulence model with standard wall function. But with the adjoint flow solver it diverges. Issue seems to be in the control settings of the adjoint flow solver. Images are included for the current settings used and the residual history for both the standard flow solver and the fluent adjoint flow solver. I would really appreciate if any of you could help me where I might be going wrong. Your help will be much appreciated. Thanks a lot and best regards, Ahmed. |
adjoint solver, fluent, fluent adjoint solver, fluent convergence, fluent solver |
convergence and off wall spacing issue | josip76 | FLUENT | 0 | June 4, 2011 18:13 |
fluent convergence problem | josip76 | FLUENT | 0 | May 26, 2011 20:08 |
Fluent 12.1 on Linux x64 Architecture Issue | fivos | FLUENT | 5 | April 24, 2010 15:19 |
Convergence Definition of Segregated Solver | Amir | FLUENT | 0 | April 18, 2006 06:21 |
Monitoring Convergence in Fluent 5.0 | Tom Plikas | Main CFD Forum | 0 | April 6, 1999 17:10 |
