DPM simulation convergence problem
Old   March 6, 2012, 10:03
Default DPM simulation convergence problem
gemini is on a distinguished road
Hi users,
I am trying to model the flow of pulverised coal (dilute phase vol frac < % 10) in a rectangular duct with bend using DPM in FLUENT. I have a convergence problem to be tackled.
In my simulation I both monitored the residuals and velocity profile at the exit and velocity profile did not converged. I got the same behaviour for each strategy i tried below. I also checked max. DPM concentration in the domain for vol. frac. < %10 condition and it is satisfied. Stochastic tracking was enabled. Both particle tracking and flow are treated steady. Realizable k-epsilon was used with full buoyancy. Flow field simulation without interaction with particles converges very well.
Strategies tried (ref: http://www.bakker.org/dartmouth06/engs150/15-dpm.pdf)
– Closer coupling between dispersed and continuous flow:
• Increase underrelaxation for discrete phase.
• Decrease number of continuous phase calculations between trajectory
calculations to less than three.
• Reduce underrelaxation factors for continuous phase.
– Decoupling of dispersed and continuous flow:
• Reduce underrelaxation factor for discrete phase.
• Increase number of continuous phase calculations between trajectory
calculations to more than fifteen.
Any recommendation will be appreciated.
Thanks.
gemini is offline   Reply With Quote
Old   March 6, 2012, 16:00
semo is on a distinguished road
is this just particle transport or also combustion?
istanbulda nerden?
semo is offline   Reply With Quote
Old   May 22, 2012, 01:41
Default Two way coupling in DPM
subha_meter's Avatar
Subhasish Mitra
subha_meter is on a distinguished road
Hi All,
Could anyone tell how 2-way coupling in DPM simulation is achieved? I have solved the continuous flow field and then created the DPM injection. Is it by lowering the URF for DPM source terms and interaction number between continuous phase and discrete phase?
A suggestion will be highly appreciated.
Regards,
SM
subha_meter is offline   Reply With Quote
Convergence problem with axial pump simulation! cnchilavert CFX 2 October 5, 2011 04:23
Need URGENT HELP for convergence problem of a turbine Pursuor CFX 5 October 3, 2011 17:44
Heat Transfer simulation: No convergence problem fiqs CFX 2 April 21, 2010 15:47
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
transient simulation: natural convection problem? Basics CFX 3 September 25, 2002 09:42
