CFD Analysis of 2D Turbulent Pipe Flow
Old   May 25, 2012, 13:47
Default CFD Analysis of 2D Turbulent Pipe Flow
Mert
erucalavera is on a distinguished road
Hi, I'm a beginner level fluent user and i need to make some analysis' for my homework.
Geometry and mesh is done but I have some problems about Fluent. I need to make analysis of a pipe flow between 3000 -10000 Re number, and my fluids will be liquid water and antifreeze. I looked over fluent but can't find any spesific section for entering reynolds number, so i guess i'll have to calculate velocity from reynolds equation and that will be my inlet velocity number, right ? For example, my diameter is 0,2m and for Re=10000 and liquid water and after calculation, velocity is 0,01 m/s. Is this a normal value for a inlet velocity ?
Also i think i've arranged my variables correctly in boundary conditions and cell zone conditions, but do you have any tips that i should do in these settings ? Or some parts that i've to be careful ? Also in the velocity inlet section, what should my turbulent intensity value be ?
And i couldn't find antifreeze material in fluent material database, did i miss it or do i have to find it on internet and add it myself ?
P.S: Sorry about my English, it's not my native language and i may have done some mistakes
erucalavera is offline   Reply With Quote
Old   May 30, 2012, 05:22
delaneyluke is on a distinguished road
Hi Mert,
Yes you will have to calculate the velocity or mass flow rate and use either of those two as yout inlet BC.
Turbulent intensity can be between 5-10% for your Re number.
Antifreeze might not be there in the database, you might have to input the properties manually.
Regards
Luke
delaneyluke is offline   Reply With Quote
ys/R term in pipe flow: cfd validation husker Main CFD Forum 0 May 8, 2012 09:29
Turbulent flow through a pipe with variable inlet velocity lobstar OpenFOAM Running, Solving & CFD 8 March 28, 2012 11:15
Laminar field as initial state for turbulent two phase pipe flow kjetil OpenFOAM Running, Solving & CFD 3 July 21, 2009 09:15
UDF for fully developed turbulent pipe flow Maged FLUENT 1 June 11, 2005 10:37
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
