specifying continuum
Old   June 19, 2012, 02:09
Default specifying continuum
thiru
mechanos is on a distinguished road
Hi all,
I have two volumes meshed using tet/hybrid in gambit. Actually, i want it to be merged into single volume with the faces connecting the two volumes to be considered as continuum. Due to dynamic memory limitations, I had to split it into two volumes for meshing. While specifying boundary conditions, i did not assign anything to those two faces. While exporting to fluent, it says a default fluid continuum has been assigned to volume 1 and volume 2. But when i open the mesh file in fluent, the two faces still remain as wall. The mesh has been exported by considering the two faces as walls, which is default in fluent. What should i do to make the walls disappear or how do i specify a continuum condition for the two walls.
Suggestions are much appreciated.
Thank you
Rgds
Thiru
mechanos is offline   Reply With Quote
Continuum Surface Force Model Miguel Main CFD Forum 4 August 4, 2012 14:56
How many mesh continuum for 2physic continuums in conjugate heat transfer?two or one? ooo STAR-CCM+ 8 May 29, 2012 01:28
Problem with ambit Lio FLUENT 4 July 6, 2004 08:23
How to solve another continuum and momentum eqn? west_wing FLUENT 0 August 25, 2003 10:00
setting boundary and continuum in GAMBIT Hakeem FLUENT 0 August 14, 2000 15:32
