Solition Animation Playback Fluent
Old   June 21, 2012, 07:42
Default Solition Animation Playback Fluent
Ivan Telnov
Gerim55 is on a distinguished road
Hello!
I have the next problem:
My research is VOF multiphase model. Calculation is ok, and I have realistic results. But I'm not satisfied with the animation, that i have like results. The Volume of air painted blue (or other color) and it isn't transperet so i can see water motion just on surfaces.
Help, guys, if someone know. I chould get animation like this: http://www.youtube.com/watch?v=DNme-gED5P4
Gerim55 is offline   Reply With Quote
Old   June 21, 2012, 09:42
Jabba is on a distinguished road
Originally Posted by Gerim55 View Post
Hello!
I didn't understand your question very well. What do you intend to show?
I see only the iso-surface in the animation you sent. Would you like to show the volume fraction like a volume (or closed surface) like the attached picture?
Jabba is offline   Reply With Quote
Old   June 21, 2012, 15:37
Ivan Telnov
Yes! This picture is better! How can i make an animation or single picture like this in fluent.
Old   June 25, 2012, 14:40
You have to define the following:
1) iso-surface equal to the volume fraction of the phase of interest;
2) create an iso-clip of volume fraction (from 0,5 to 1,0, for example) attached to all the surfaces of your domain;
3) plot both.
You may adjust the colors through the Scene panel as well.
In step 2, if you want, you may first create a single surface from your entire domain (I think it is in the Zone panel). It is easier for creating the iso-clip.
Regards and let me know if it helped.
Old   June 26, 2012, 01:57
Ivan Telnov
3) plot both.
Thanks! It's very usefull information and i've got surfaces of my interest. Could you tell me, how to make a closed surface or valume painted on picture you sent? And I have a question about valume fraction : if my domain filled to half with primary phase on first timestep, what volume fraction will be equal? Is it 0.5 ?
Old   June 26, 2012, 09:28
Actually you will have volume fraction values from 0 to 1.0, since you will have a gradient due to mesh (unless if you have a very fine mesh so the interface will be pretty sharp).
Following the previous procedure I sent you, you may obtain a picture similar to that one.
Commom sense is to set the iso-surface as 0.5 for the volume fraction of liquid. In that picture, it is the lighter green surface.
The iso-clip (you will have to define a range) should be from 0.5 to 1.0 for the volume fraction of liquid. So the "role" of the iso-clip will be to show the "wetted surfaces" of your domain. It will be the darker green in the picture.
The two entities together will define a closed surface, similar to a volume.
I think that this webiste will be helpful for you:
http://pt.scribd.com/doc/62308472/Be...otive-Industry
A lot of useful information.
Regards.
Animation Sequence in Fluent with unsteady state Condition cycho FLUENT 6 July 26, 2014 06:53
Graphical Animation of Fluent Simulation Data in Tecplot Musa FLUENT 4 January 19, 2012 06:44
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
how to playback animation? wanghong FLUENT 1 April 18, 2005 10:05
Fluent animation commands Khalil Bostan Main CFD Forum 2 March 22, 2002 07:36
