July 17, 2012, 12:20 |
microchannel's modeling
raha
hi
i want to modelling a micro channel , micro channel is solid and silicon , fluid that flows through it is nano fluid , my problem is where i choose silicon as a solid in fluent (material's section) my materials list just changes in to aluminum !!!! please some body help me im a beginner in cfd |
July 18, 2012, 04:43 |
Marion
Are you sure there is solid silicon in the materials database? In my version of Fluent (12.1) silison is only defined as a fluid. In the create/edit materials panel if Ichoose "Solid" from he drop down menu (upper right corner) I cannot see silicon. There is solid silicon in the fluid database though - but I guess it can only be defined as fluid, and cannot replace Aluminum as a solid. Marion. |
July 19, 2012, 08:09 |
raha
thanks marion . the version of my fluent is 6.3 . so you mean that i should choose silicon as a fluid ? but once i solved the problem with choosing silicon as a fluid and my teacher said its wrong
July 19, 2012, 08:53 |
Marion
No - I jut meant that you cannot choose Silicon in the solids as it is not there... Have you tried creating your own solid using the silicon properties?
July 19, 2012, 09:04 |
raha
So u mean ,i crate a new material with solid silicon properties but choose the solid option in materials menu?
July 19, 2012, 09:07 |
Marion
Yes! That's what I mean.
July 19, 2012, 09:14 |
raha
Thanks so much Marion.
micro channel, two phase flow |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 11:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
Solid Modeling | Chris | Main CFD Forum | 10 | July 2, 2002 07:12 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
Extrusion Modeling | Elliot Schwartz | Main CFD Forum | 1 | September 11, 1998 19:08 |
