April 21, 2016, 11:18 |
Fluent - Modelling a 2D Rotating flow
Quentin Baar
Hello every one !
For my master thesis, I'm trying to model a 2D rotating flow. Goal : Streamlines parallel to the geometry (circular) (cfr. figures). It is first experience on CFD so I do my best. I'm working with a student licence so I do not have access to the ANSYS training. I was think about a single reference frame model. Simple mapped face meshing (cfr.figures). I don't know how to configure the axis (of rotation) of the axisymetric model. I just put my global coordinate system as my wished center of rotation. But when I "Check case...", It recommend me to "translate the mesh for axisymmetric geometry containing nodes below the x-axis." How to create and define an axis of rotation ? Setup : - I choose K-e viscous model and Enhanced wall treatment. - Cell Zone conditions : frame motion of the geometry zone (Rotational velocity 50 rad/s) I think that my problem is to configure my boundary conditions : What are your advises for the inlet ? I was thinking about only configure it as "Velocity-inlet" type with only a swirl angular velocity of 50 ras/s to follow the frame motion. I want that the flow For the solution methods, I use "Couple - Presto ! - First order upwind for all and check Pseudo Transient" as recommended. But when I initialize the solution "convergence tolerance of 1-06 not reached". Several problems on my setup I think. Any advises will be very helpful ! I didn't see other subject with real solution about that kind of model... Thanks you in advance ! Last edited by QuentinB; April 22, 2016 at 05:20. |
April 21, 2016, 13:23 |
First step
Quentin Baar
How to create an axis ? In the Design Modeler or Meshing ?
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Question Regarding Modelling Internal Flow | Alteran | CFX | 1 | September 4, 2013 12:07 |
Does fluent calculate reversed flow situations more simply than it should? | heksel8i | FLUENT | 0 | August 8, 2013 08:03 |
Transient flow in fluent | linyx | FLUENT | 15 | April 24, 2013 09:54 |
Port flow modelling in FLUENT | zeppelin101 | FLUENT | 0 | January 14, 2011 10:17 |
