graph of velocity against distance
Like Tree4Likes
  • 1 Post By Touré
  • 1 Post By Touré
  • 1 Post By Touré
  • 1 Post By Touré
Old   August 10, 2012, 13:02
Default graph of velocity against distance
zaynah K.
zaynah04 is on a distinguished road
Dear everyone..
I am relatively new to fluent, I had done a 2D simulations of some buildings and i want to plot a graph of velocity against distance..
the problem is that in the drop down menu for surfaces i see a lot of options, hence i am confused...i also see a lot of zones in the drop down menu..
please i really need someone to guide me in that..
thanking you all in advance
zay
zaynah04 is offline   Reply With Quote
Old   August 10, 2012, 17:31
Guiliguili
Touré is on a distinguished road
Go to Mesh -> Display
Then you can select on surface and click on Display to know which surface it.
Do it for all surfaces. to understand the relation between the names and the geometry.
zaynah04 likes this.
Touré is offline   Reply With Quote
Old   August 11, 2012, 03:32
zaynah K.
Thanks You a lot Toure..
it helped....
In my plot now, when i am plotting velocity against distance, what parameter should i normally use for the surface?
I mean i want to compare two graphs in my project, hence i am confused on the parameters displayed...
thanks in advance
Old   August 11, 2012, 11:08
Guiliguili
If you want to have a map color of any variable on a surface such as the pressure :
Graphics and animation -> Contours
Then select filled in "Options", the variable in "Conours of" and the surfaces in "Surfaces"
If you want to plot any variable versus of any other variable on a line (velocity vesus distance) :
Plots -> XY Plot
Be sure that Position on X Axis and Position On Y Axis are not selected in the "Solution XY Plot" window
Click on New surface and select Line/Rake in the "Solution XY Plot" window
Draw the line you want to plot in the "Line/Rake Surface" window
Draw a line that represent distance for you
Close the "Line/Rake Surface" window
Then select the variable for X axis and the variable for Y axis in the "Solution XY Plot" window
Click on Plot.
If you want to export the data of the graph to a file , select "Write to File".
Then your "Plot" button become a "Write" button. Click on it and save the plot data to a file. You can reload many files with the "Load" button on the same graph.
Old   August 11, 2012, 16:01
zaynah K.
Thank you a lot Toure..
You told me what i could not find in books..
I am grateful..
zay
Old   August 11, 2012, 23:20
Guiliguili
Keep going
Old   August 12, 2012, 14:42
zaynah K.
dear toure..
Fluent solve a lot of equations. including the Navier-Stokes one.
how do i know which equation solve for example in a laminar flow around a cube or circle?
thanks in advance
Old   August 12, 2012, 15:21
Guiliguili
I don't understand the question. You chose the equations by selecting a model in Models
1. Models -> Viscous (Inviscid, Laminar or Turbulent models such as k-epsilon and others)
2. You can add heat transfer Models-> Energy (On)
3. .....
Old   August 12, 2012, 15:24
zaynah K.
i want to knnow all the equations which fluent solve to get the result.
example, when i model a cube in laminar flow or turbulent, i iterate and get the result. i want to know which equations did fluent use for that?
thanks
Old   August 12, 2012, 20:22
Guiliguili
It's ANSYS FLUENT Theory Guide that you need
A not too new version but it does change a lot between version 12, 13 and 14
https://www.sharcnet.ca/Software/Flu...df/th/flth.pdf
Old   August 14, 2012, 01:16
zaynah K.
i am using fluent 6.3... but am studying the book..
thanks toure...
Old   August 14, 2012, 01:36
zaynah K.
hi,
After i itererate my program ( turbulent) and after convergence is reached , when i display velocity contour i got error messages.
"Error message from graphics function Compute_Text_Extent:
The device for '/driver/msw/win+w0/inner/scale' doesn't seem to be alive
Error: Floating point error: invalid number
Error Object: ()"
can you Dear Toure please help me out here?
Thanks in advance
zay
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
How to calculate Velocity? Kali Sanjay Phoenics 1 May 1, 2006 13:57
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
