different answers from different UNDER RELAXATION FACTOR |
August 18, 2012, 12:39 |
misagh
Rep Power: 14 |
i have a 2-D micro-channel that a constant heat flux is applied on its walls. when i change under relaxation factor or discretization of momentum and energy the result(e.g conv. heat transfer coeff.[h]) changes extensively(although the equations have been solved and converged) what can i do?which under relaxation factor is suitable? best regards. |
August 18, 2012, 20:59 |
Guiliguili
Rep Power: 15 |
Do you have enough elements?
August 19, 2012, 06:10 |
misagh
Rep Power: 14 |
yes, 100'000 elements.im sure the number of elements are enough.
when i change URF in other geometries like macro scale the difference between results is less than 2 %.but in this case(microtube) changes are sever(more than40-50 %). any guidance is appreciated. |
August 19, 2012, 08:34 |
Guiliguili
Rep Power: 15 |
It could be due to the definition of your slip condition. See pages 17 and 18 of http://ethesis.nitrkl.ac.in/1934/1/avinash.pdf
Under relaxation factor for external coupling | dhxlxz | CFX | 10 | August 11, 2015 20:52 |
under relaxation factor and the steady state | jing113cn | FLUENT | 0 | November 2, 2009 12:13 |
Relaxation factor | Benzaa | Main CFD Forum | 1 | August 18, 2009 07:27 |
Question on adjusting relaxation factor | CFD Rookie | Main CFD Forum | 3 | January 26, 2004 14:37 |
Relaxation factor | Moon | Siemens | 1 | June 13, 2003 11:13 |
