August 27, 2012, 23:12 |
Problem with non-premixed model
wei jet
I am using pdf-mixture (non-premixed model, equilibrium, non-adiabatic) with dynamic mesh to simulate in-cylinder pressure of a diesel engine. The predicted in-cylinder temperature would experience sudden increase until the maximum limit of the PDF table (the spike occurs at 900K) but the predicted in-cylinder pressure would have a sudden decrease. This makes no sense at all as the temperature and pressure should be proportional to each other in a closed system. As for the detail of the pdf table generation, C12H23 is simply set as the fuel and O2,N2 are set as the oxidiser.
August 7, 2014, 08:34 |
Dhanashree
Rep Power: 11 |
did you get a solution for ur problem? |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Turbulence model for mixing problem | nileshjrane | OpenFOAM Running, Solving & CFD | 1 | September 7, 2010 17:48 |
premixed flame modeling problem | peiyong wang | CFX | 1 | July 18, 2008 12:02 |
Non premixed model - combustion validation problem | David | FLUENT | 2 | October 24, 2003 10:06 |
Two phase Eulerian Model Problem | senthil | FLUENT | 5 | May 21, 2003 02:55 |
