September 28, 2012, 11:19 |
Difference between Fluent and CFX
Hamed
Dear friends,
In fact I have simulated the flow of water in a long tube with flattened sections with gravity effects, unfortunately the fluent solves the flow not correctly and I think that fluent does not uses gravity effects but I have solved this problem with CFX and CFX solves the flow field very good and CFX uses gravity effects, does anybody know the reason of this problem, the figure of a contour of CFX and Fluend is attached. Sincerely |
October 1, 2012, 04:16 |
Philipp
Rep Power: 26 |
Did you set your gravity force in Fluent?
difference between CFX and fluent | rashmi | FLUENT | 17 | February 3, 2020 07:29 |
Different result in CFX and fluent for mass trans.? is segregated better? | ftab | CFX | 7 | September 27, 2012 07:57 |
Difference between CFX and FLUENT | TypeSpeed | CFX | 3 | January 6, 2010 15:55 |
Difference between Fluent, CFX and ICEM CFD | holyo | ANSYS | 1 | July 23, 2009 10:18 |
Fluent Vs CFX, density and pressure | Omer | CFX | 9 | June 28, 2007 04:13 |
