Modelling strecthing/shrinking plate in FLUENT |
October 24, 2012, 06:34 |
Deepak .S.Jain
I need to solve the following problem numerically and I thought FLUENT will be a good option .
Problem statement: Flow of viscous incompressible, fluid over a generalized strecthing/shrinking wall. For the start I prepared a rectangular domain as my flow domain and now while specifying the boundary conditions I was little confused. The research paper I am referring gives the following BC'ns for the bottom wall it gives u(x) = ax+b v = constant (can be +ve or -ve) at the far field the fluid is quiescent ... so i suppose for the upper boundary i will have to give u=0 and v=0 I am not able to figure out what to give at the inlet and the outlet also do i need to use UDF for the bottom wall velocity condition and is it a moving mesh problem. I would also like to know whether openFoam would be easier in this regards?? I was trying to attach the reference paper but seems its too large size...please guide me in this regards. |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Engine modelling using fluent - advice | nat2479 | FLUENT | 0 | February 1, 2011 14:18 |
Modelling two fluids in Fluent | skaboy607 | FLUENT | 7 | January 27, 2011 05:55 |
Modelling an actuator disk in FLUENT | teymourj | Main CFD Forum | 0 | April 28, 2009 21:42 |
Need Help on Fluent Modelling Laminar on BluffBody | ary | Main CFD Forum | 1 | May 19, 2005 05:59 |
