how to calculate circulation in ansys fluent 13.0 |
November 10, 2012, 05:34 |
ijlal
i am performing numeruical experiment on subsonic airfoil in ansys fluent 13.0. i want to calculate circulation around the airfoil on the defined shape of rectangle. is there any way of calculating circulation??????? help me...i am new to cfd
November 14, 2012, 11:34 |
Lucky
Rep Power: 65 |
Integrate vorticity over the entire domain or just the rectangle (volume integral), that gives you circulation.
If you need to: use definition of circulation and apply Stoke's theorem to convince yourself that it gives the same result. |
November 15, 2012, 04:53 |
ijlal
no..it would not give the circulation. i need user defined codes that would calculate simultaneously along with drag and lift history ...stokes theorem cannot be applied to the area inside of which there is airfoil...
November 15, 2012, 11:19 |
Lucky
Rep Power: 65 |
Stoke's theorem should work even around airfoils?
November 17, 2012, 04:43 |
ijlal
we want circulation on a rectangle around airfoil. and stokes theorem is applied for deformable boundary.since the rectangle contains airfoil and hence it is not applied here....can you suggest me some other way....have you ever calculated it before???????
ansys, circulation, fluent, how to |
Fluent v6.3.26 better than Ansys v12.1 | jemyungcha | FLUENT | 2 | August 24, 2012 23:10 |
Strange ANSYS Meshing 13.0 Problem | brunob | ANSYS Meshing & Geometry | 3 | June 21, 2011 20:03 |
Fluent validation test for calculate the drag of a car | ostervi | FLUENT | 0 | June 12, 2009 12:59 |
Urgent help needed- FLUENT to ANSYS | Omer | Main CFD Forum | 3 | September 18, 2006 10:24 |
Hot News: Ansys Buys Fluent | Jonas Larsson | Main CFD Forum | 23 | February 22, 2006 17:12 |
