Update_Time_Level: invalid data
Like Tree10Likes
  • 8 Post By mahesh.j90
  • 1 Post By LuckyTran
  • 1 Post By HHOS
Old   November 10, 2012, 14:10
Default Update_Time_Level: invalid data
Jenny
Jenny_W is on a distinguished road
I'm running an LES case with dual-time-iterate command. The simulation was running fine with RANS but once I switch to LES, FLUENT reports this error:
I really do not know what it means and what is wrong because all other setup is the same. If anyone has any idea, please kindly give me some suggestions. Thank you.
Jenny
Jenny_W is offline   Reply With Quote
Old   April 24, 2013, 16:49
Negin Nazarian
nenazarian is on a distinguished road
Hi, did you find the reason for this error?
I would appreciate if you share it here.
Cheers,
Negin
nenazarian is offline   Reply With Quote
Old   August 24, 2014, 07:53
Mahesh J Rao
mahesh.j90 is on a distinguished road
Nothing is wrong on your side.
Use
"/solve/iterate 1" and then
"/solve/dual-time-iterate 100 20"
They say this is some kind of strange error that comes when you use it in command line mode (with -g option)
Source:http://stone-circle.blogspot.in/2010...fluent-in.html
Sun, Mazze[ITA], rmn_990 and 5 others like this.
mahesh.j90 is offline   Reply With Quote
Old   December 2, 2019, 02:15
deblina roy
deblina roy is on a distinguished road
I am facing the same error in GUI window. using time step :0.001, number of iteration :100.
Error at host: Update_Time_Level: invalid data
Error: Update_Time_Level: invalid data
What do i need to change to make the iterations run?
deblina roy is offline   Reply With Quote
Old   December 3, 2019, 12:21
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
First thing you need to do type /solve/iterate 1 (or /solve/iterate 10 if you want) and see what happens. If there is already a prevailing problem, then you'll get another possibly different error.
Do not click the calculate button if this already does not work because clicking the calculate button will make the solution step forward in time.
mahesh.j90 likes this.
LuckyTran is online now   Reply With Quote
Old   October 8, 2020, 10:41
Default Solution
HHOS is on a distinguished road
It is an old post, but, here is the solution.
When restarting a transient simulation, the error “Update_Time_Level: invalid data” occurs.
Solution:
In the journal file use:
/solve/iterate 1 /solve/dual-time-iterate 100 20
They say this is some kind of strange error that comes when you use it in command line mode (with -g option)"
I got it from the page:
http://www.cfdresearch.com/ansys-fluent-solutions/
Javons Wong likes this.
HHOS is offline   Reply With Quote
Old   March 17, 2021, 09:57
cuneyt
mcuneytk is on a distinguished road
Works.
Thanks a lot.
mcuneytk is offline   Reply With Quote
error, les, parallel computing, update_time_level
ã€Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 07:51
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
