November 10, 2012, 14:10 |
Update_Time_Level: invalid data
Jenny
I'm running an LES case with dual-time-iterate command. The simulation was running fine with RANS but once I switch to LES, FLUENT reports this error: Update_Time_Level: invalid data I really do not know what it means and what is wrong because all other setup is the same. If anyone has any idea, please kindly give me some suggestions. Thank you. Jenny |
April 24, 2013, 16:49 |
Negin Nazarian
Hi, did you find the reason for this error?
I would appreciate if you share it here. Cheers, Negin |
August 24, 2014, 07:53 |
Mahesh J Rao
Nothing is wrong on your side.
Use "/solve/iterate 1" and then "/solve/dual-time-iterate 100 20" They say this is some kind of strange error that comes when you use it in command line mode (with -g option) Source:http://stone-circle.blogspot.in/2010...fluent-in.html |
December 2, 2019, 02:15 |
deblina roy
Rep Power: 8 |
I am facing the same error in GUI window. using time step :0.001, number of iteration :100. Error at host: Update_Time_Level: invalid data Error: Update_Time_Level: invalid data What do i need to change to make the iterations run? |
December 3, 2019, 12:21 |
Lucky
Rep Power: 66 |
First thing you need to do type /solve/iterate 1 (or /solve/iterate 10 if you want) and see what happens. If there is already a prevailing problem, then you'll get another possibly different error.
Do not click the calculate button if this already does not work because clicking the calculate button will make the solution step forward in time. |
October 8, 2020, 10:41 |
Solution
Rep Power: 12 |
It is an old post, but, here is the solution.
" When restarting a transient simulation, the error “Update_Time_Level: invalid data” occurs. Solution: In the journal file use: /solve/iterate 1 /solve/dual-time-iterate 100 20 They say this is some kind of strange error that comes when you use it in command line mode (with -g option)" I got it from the page: http://www.cfdresearch.com/ansys-fluent-solutions/ |
March 17, 2021, 09:57 |
cuneyt
Rep Power: 5 |
Works.
Thanks a lot. |
error, les, parallel computing, update_time_level |
ã€Help】"Error: Update_Time_Level: invalid data" | Chen | FLUENT | 2 | August 24, 2014 07:51 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
