Unstructured mesh (on Gridgen) doesn't run in FLUENT |
November 15, 2012, 10:35 |
Santiago Lopez Castano
Rep Power: 15 |
Hi Guys,
I'm not an expert using unstructured meshes on FLUENT. The thing is that I had to make a hybrid mesh (prisms + tets) amid my (3D structured) domain in an attempt to reduce the number of nodes. So what a I did was to extrude the unstructured mesh on the walls and to initialize an unstructured block on the core of the block. When I run a 1st order SIMPLEC with a k-e closure, everything is fine. But when I try to shift gears to a 2nd order scheme the case automatically diverges. It doesn't even bother to make one time step. Thanks in advance, S |
November 15, 2012, 12:06 |
Lucky
Rep Power: 66 |
I would check grid quality and try to improve it as much as you can. For meshes with skewed cells can easily lead to those symptoms. Look for the cells between the prism layer and core mesh. This is usually where the skewed cells show up.
November 16, 2012, 12:46 |
Rep Power: 14 |
I've heard SimpleC can have big issues with any skewness since it sets under-relaxation factors to 1 for convergence speed up....did you try using Simple?
November 16, 2012, 13:02 |
Lucky
Rep Power: 66 |
I don't think this is the case, since a 1st order scheme converged without difficulty, but one can always try and find out if there is time.
November 16, 2012, 14:48 |
Quality
Rep Power: 15 |
What would be a good quality criteria for unstructured meshes? The same as for structured (Jacobian/skewness centroid/aspect ratio)?
[ICEM] export hexa mesh to fluent | Wieland | ANSYS Meshing & Geometry | 37 | January 23, 2013 03:27 |
[ICEM] Tips for 3D tetra mesh quality for Fluent transient run. Rotary Engine | Catthan | ANSYS Meshing & Geometry | 0 | June 18, 2012 12:46 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
Exporting structured mesh from ICEMCFD to Fluent? | jeevan kumar | FLUENT | 1 | January 23, 2012 11:21 |
unstructured mesh grid independence for Fluent | Shane Schouten | FLUENT | 0 | October 11, 2006 16:50 |
