Home > Forums > FLUENT
Moving nozzle
Old   November 20, 2012, 00:02
Default Moving nozzle
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Hello
I want to model a nozzle moving at a certain rate across its axis. Like moving about a certain point along its axis if viewed in 2D. The whole nozzle is moving while simultaneously the flow is passing through it. How I can model it using dynamic mesh while the mesh is not disturbing the whole domain of nozzle is moving across a gimbal point (which is located on its axis)
Shamoon Jamshed is offline   Reply With Quote
Old   November 23, 2012, 02:22
Default moving nozzle
Shamoon Jamshed
Hello
I am not getting any reply please help me . Its urgent
Old   November 29, 2012, 13:01
Default moving nozzle wall
Shamoon Jamshed
Guys please help me out I need it urgent.
Old   November 29, 2012, 17:31
Default RBF Morph
meb
Marco Evangelos Biancolini
meb is on a distinguished road
not sure to understand your problem.
The problem is 2d or 3d?
How movement of the nozzle is accommodated by remaining domain?
You have a far flow in which the nozzle is immersed?
RBF Morph
(http://rbf-morph.com) could be the right solution for your problem. It can be used both for internal and external flows in steady and transient analyses (and it seems you have to prescribe the movement in advance, isn't it?).
This GIF demontrate how a carotid bifurcation can be deformed.
meb is offline   Reply With Quote
Old   November 30, 2012, 18:26
Shamoon Jamshed
Ans: 2d
Ans: Not sure (but the type of movement of right artery side ways you showed except swelling (bulging) is required)
Ans: no far flow just pressure inlet in beginning of convergent
Old   December 1, 2012, 04:35
Default RBF Morph 2D
meb
You can do it. A not official released version of RBF Morph for 2D exists. Contact info@rbf-morph.com for details.
Ans: 2d
Old   December 1, 2012, 10:59
Shamoon Jamshed
does fluent accept Rb-morph? What about compatibility.
Old   December 2, 2012, 05:38
Default RBF Morph Fluent add on
meb
Sure!
RBF Morph is an add-on for Fluent fully integrated in the solver. So you can move the mesh at solution stage, even in transient analysis.
Thread Tools
Trackbacks are On
jagged, ragged edges... ziemowitzima OpenFOAM Native Meshers: snappyHexMesh and Others 138 July 23, 2012 23:41
How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 11:46
Moving mesh in Fluent fivos FLUENT 0 April 2, 2010 09:45
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 01:45
