simulation of free surface of stirred tank using vof |
November 23, 2012, 02:35 |
Jamal Foroozesh
Hi alls,
I want to simulate free surface of stirred tank. I've solved my problem but it seems that results are wrong. System should be stable after a period of time, but did not stable. I think thak I don’t do a part of problem. What should I do that I have not done? Step by step of my problem: Read msh file 1) Make grid interfaces (rotor-stator interface) 2) Set multiphase model to VOF with default parameters 3) Set K-E with default parameters 4) Copy water-liquid from materials database 5) Define Air as primary phase 6) Define water as secondary phase 7) Operating condition: active gravity and set -9.81 to Z, (0 0 26.5) as reference pressure location 8) Boundary condition: A) Rotor fluid: whether moving mesh or mrf , 200rpm B) Rest fluid: stationary C) Impeller: stationary D) Shaft: absolute rotational, 200rpm E) Top of tank: symmetry F) Tank walls: no slip 10) initialize, init with default parameters 11) Adapt/ region/ (Xmin=-12, Xmax=12) (Ymin=-12, Ymac=12) (Zmin=0, Zmax=21.5)/ mark 12) initialize/ patch/ volume fraction of water in marked zone is set to 1 13) all parameters of solution is default of fluent 14) time step=0.001 or 0.0001 15) iterate |
November 23, 2012, 04:18 |
Maxime Perelli
Rep Power: 41 |
pictures of your weird results?
In memory of my friend Hervé: CFD engineer & freerider |
November 23, 2012, 05:01 |
Jamal Foroozesh
they are here: http://www.cfd-online.com/Forums/flu...tml#post393765
November 23, 2012, 05:07 |
Maxime Perelli
Rep Power: 41 |
i would say interfaces issue -- are those spots exactly where interfaces-intersection are ?
November 23, 2012, 05:13 |
Jamal Foroozesh
November 23, 2012, 05:21 |
Maxime Perelli
Rep Power: 41 |
the four red you see on each picture...
November 23, 2012, 05:27 |
Jamal Foroozesh
November 23, 2012, 06:02 |
Maxime Perelli
Rep Power: 41 |
then here is the issue.
how many interfaces did you define?
November 23, 2012, 06:15 |
Jamal Foroozesh
two interface, 1)rotor perimeter 2) part of rest tank that contact with rotor (You said to me earlier )
http://www.cfd-online.com/Forums/ans...nk-gambit.html |
November 23, 2012, 06:19 |
Maxime Perelli
Rep Power: 41 |
I would say 3:
*rotor perimeter *top cap of rotor *bottom cap of rotor No? Anyway are you dealing with moving mesh? if yes is it moving properly?
November 23, 2012, 06:26 |
#11 |
Jamal Foroozesh
November 23, 2012, 06:44 |
#12 |
Maxime Perelli
Rep Power: 41 |
So 2 or 3 interfaces defined in Fluent?
November 23, 2012, 06:56 |
#13 |
Jamal Foroozesh
November 23, 2012, 07:02 |
#14 | |
Maxime Perelli
Rep Power: 41 |
defined in gambit: top cap rotor as interface 1 top cap stator as interface 2 bottom cap rotor as interface 3 bottom cap stator as interface 4 perimeter rotor as interface 5 perimeter stator as interface 6 Then in fluent: grid interface A using interfaces 1 & 2 grid interface B using interfaces 3 & 4 grid interface C using interfaces 5 & 6
November 23, 2012, 07:07 |
#15 | |
Jamal Foroozesh
I'll do the things you said and report the results to you |
November 23, 2012, 08:26 |
#16 |
Rick
Rep Power: 26 |
Jamal,
also, if you use mrf you don't need any interface!Create interfaces, as explained by max, only if you use sliding mesh. If you use mrf you have only to define 2 fluid zones (rotor and stator), without interfaces. EDIT: "if you use mrf you don't need any interface!" --> if you have a conformal mesh Last edited by ghost82; November 23, 2012 at 08:46. |
November 23, 2012, 08:40 |
#17 |
What if the mesh is not conformal? Whether it is mrf or sliding mesh, interfaces should be defined as mrf can be thought as a special case of sliding mesh.
November 23, 2012, 08:45 |
#18 | |
Rick
Rep Power: 26 |
Looking at the mesh model, I think it is quite simple to not create interfaces. Daniele |
November 23, 2012, 08:55 |
#19 | |
I agree..... Thats perfect |
November 23, 2012, 08:57 |
#20 |
Jamal Foroozesh
Thanks all to your responses
VOF in free surface | alilouu | FLUENT | 0 | September 27, 2011 06:32 |
VOF and Free surface model...are they same? | Kushagra | CFX | 1 | November 14, 2008 12:36 |
Can I have solid in the free surface simulation? | ggbaby | Siemens | 0 | September 5, 2006 05:45 |
Free surface of Step with VOF | Azin Sharafeddin | FLUENT | 1 | May 26, 2004 05:24 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
