simulation of free surface of stirred tank using vof
Like Tree6Likes
Old   November 23, 2012, 02:35
Default simulation of free surface of stirred tank using vof
Jamal Foroozesh
jamalf64 is on a distinguished road
Hi alls,
I want to simulate free surface of stirred tank.
I've solved my problem but it seems that results are wrong.
System should be stable after a period of time, but did not stable.
I think thak I don’t do a part of problem.
What should I do that I have not done?
Step by step of my problem:
Read msh file
1) Make grid interfaces (rotor-stator interface)
2) Set multiphase model to VOF with default parameters
3) Set K-E with default parameters
4) Copy water-liquid from materials database
5) Define Air as primary phase
6) Define water as secondary phase
7) Operating condition: active gravity and set -9.81 to Z, (0 0 26.5) as reference pressure location
8) Boundary condition:
A) Rotor fluid: whether moving mesh or mrf , 200rpm
B) Rest fluid: stationary
C) Impeller: stationary
D) Shaft: absolute rotational, 200rpm
E) Top of tank: symmetry
F) Tank walls: no slip
10) initialize, init with default parameters
11) Adapt/ region/ (Xmin=-12, Xmax=12) (Ymin=-12, Ymac=12) (Zmin=0, Zmax=21.5)/ mark
12) initialize/ patch/ volume fraction of water in marked zone is set to 1
13) all parameters of solution is default of fluent
14) time step=0.001 or 0.0001
15) iterate
jamalf64 is offline   Reply With Quote
Old   November 23, 2012, 04:18
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
pictures of your weird results?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 23, 2012, 05:01
Jamal Foroozesh
they are here: http://www.cfd-online.com/Forums/flu...tml#post393765
Old   November 23, 2012, 05:07
-mAx-'s Avatar
Maxime Perelli
i would say interfaces issue -- are those spots exactly where interfaces-intersection are ?
Old   November 23, 2012, 05:13
Jamal Foroozesh
which spots?
Old   November 23, 2012, 05:21
-mAx-'s Avatar
Maxime Perelli
the four red you see on each picture...
Old   November 23, 2012, 05:27
Jamal Foroozesh
yes, spots and interfaces are overlap.
Old   November 23, 2012, 06:02
-mAx-'s Avatar
Maxime Perelli
then here is the issue.
how many interfaces did you define?
Old   November 23, 2012, 06:15
Jamal Foroozesh
two interface, 1)rotor perimeter 2) part of rest tank that contact with rotor (You said to me earlier )
http://www.cfd-online.com/Forums/ans...nk-gambit.html
Old   November 23, 2012, 06:19
-mAx-'s Avatar
Maxime Perelli
I would say 3:
*rotor perimeter
*top cap of rotor
*bottom cap of rotor
No?
Anyway are you dealing with moving mesh? if yes is it moving properly?
Old   November 23, 2012, 06:26
Jamal Foroozesh
I would say 3:
*rotor perimeter
*top cap of rotor
No?
Exactly, I've done all these things and moving is proper
Old   November 23, 2012, 06:44
-mAx-'s Avatar
Maxime Perelli
So 2 or 3 interfaces defined in Fluent?
Old   November 23, 2012, 06:56
Jamal Foroozesh
I defined rotor perimeter, top cap of rotor, bottom cap of rotor as one interface in GAMBIT and every three are defined rotor interface(as one interface) in fluent
Stator interface is defined similar to rotor
Old   November 23, 2012, 07:02
-mAx-'s Avatar
Maxime Perelli
It is not correct in regards of topology, because for one interface all surfaces should slide on each other
defined in gambit:
top cap rotor as interface 1
top cap stator as interface 2
bottom cap rotor as interface 3
bottom cap stator as interface 4
perimeter rotor as interface 5
perimeter stator as interface 6
Then in fluent:
grid interface A using interfaces 1 & 2
grid interface B using interfaces 3 & 4
grid interface C using interfaces 5 & 6
Old   November 23, 2012, 07:07
Jamal Foroozesh
defined in gambit:
Then in fluent:
Thank you so much
I'll do the things you said and report the results to you
Old   November 23, 2012, 08:26
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Jamal,
also, if you use mrf you don't need any interface!Create interfaces, as explained by max, only if you use sliding mesh.
If you use mrf you have only to define 2 fluid zones (rotor and stator), without interfaces.
EDIT: "if you use mrf you don't need any interface!" --> if you have a conformal mesh
ghost82 is offline   Reply With Quote
Old   November 23, 2012, 08:40
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by ghost82 View Post
Jamal,
What if the mesh is not conformal? Whether it is mrf or sliding mesh, interfaces should be defined as mrf can be thought as a special case of sliding mesh.
Far is offline   Reply With Quote
Old   November 23, 2012, 08:45
ghost82's Avatar
Rick
Yes Far, if you have a non conformal mesh, then interfaces are necessary also for mrf; however, in my cases, if I used mrf, I preferred to not create interfaces, as in post processing some discontinuities may appear on non conformal interfaces, between fluid zones.
Looking at the mesh model, I think it is quite simple to not create interfaces.
Daniele
Old   November 23, 2012, 08:55
Far
Sijal
Daniele
I agree..... Thats perfect
Old   November 23, 2012, 08:57
Jamal Foroozesh
Thanks all to your responses
VOF in free surface alilouu FLUENT 0 September 27, 2011 06:32
VOF and Free surface model...are they same? Kushagra CFX 1 November 14, 2008 12:36
Can I have solid in the free surface simulation? ggbaby Siemens 0 September 5, 2006 05:45
Free surface of Step with VOF Azin Sharafeddin FLUENT 1 May 26, 2004 05:24
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
