Dynamic mesh problem
Old   June 15, 2004, 17:06
Default Dynamic mesh problem
Jim
Hi All,
I have a trouble to run the fluent tutorial Dynamics mesh. When I try to compile the file: valve.c, the following messages show up:
CMD.EXE was started with the above path as the current directory. UNC paths are not supported. Defaulting to Windows directory. 'nmake' is not recognized as an internal or external command, operable program or batch file.
If you have any ideas, please help me. Thanks.
Sincerely, Jim zhang
Old   June 15, 2004, 20:40
Default Re: Dynamic mesh problem
Podila
okie I guess there might be two reasns behind it: 1. U have not set the path. 2. U are not compiling from the correct directory. U have to compile inside the libudf>src>2d/dp/3d/dp from there copy the path and change it. Go to the command prompt, copy the path, by cd ...and then give nmake. Podila
Old   June 15, 2004, 21:19
Jim Zhang
Hi, Podila,
I have tried it, and the following is some error messages showing up. Thanks.
C:\Documents and Settings\Jim Zhang\My Documents\help_FLUENT\tutfiles\dynames h\libudf\ntx86\2d>nmake
Microsoft (R) Program Maintenance Utility Version 6.00.8168.0 Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
cl /c /Za /DUDF_EXPORTING -Ic:\fluent.inc\fluent6.1.22\ntx86\2d -Ic:\fl uent.inc\fluent6.1.22\src -Ic:\fluent.inc\fluent6.1.22\cortex\src -Ic:\fluent. inc\fluent6.1.22\client\src -Ic:\fluent.inc\fluent6.1.22\tgrid\src -Ic:\fluent .inc\fluent6.1.22\multiport\src ..\..\src\valve.c 'cl' is not recognized as an internal or external command, operable program or batch file. NMAKE : fatal error U1077: 'cl' : return code '0x1' Stop.
Old   June 16, 2004, 08:27
Podila
okie which tutorail is that. Please provide the details of the tutorail I will see whether it works for me. Podila
Old   June 16, 2004, 11:39
jim
Dynamics mesh tutorial, thanks
Old   June 16, 2004, 14:34
STK
From my experience, i have seen that udf files in some machines are not compiled automatically by fluent gui (the *.c files). This happens in your machine. Don't worry it is simple. What you have to do is to open the command prompt (cmd in start-run), then you go to the bin directory of your MICROSOFT VISUAL STUDIO FOLDER,you find the VCVARS32.BAT (this execute command setting the enviroment) and you print it. After you have activated vcvars32.bat, you launch fluent (do it from an another command prompt to be sure) and you will see that you can compile valve.c, which is a correct generated code, as you will confirm.(remember first build and then load the library) good luck!
Old   June 16, 2004, 16:12
Jim
Hi,thank you all, and I got it. The problem is in the visual c++. when I remove the visual c++, and reinstall it, every thing is OK. Thanks for your help. Jim
Old   January 29, 2013, 03:32
samrat himvanth nanduri
samcfd is on a distinguished road
Hi i tried loading the VALVE.c file into ANSYS FLUENT and i get this message
1 file(s) copied.
(system "copy c:\fluent.inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2d\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\2d")()
Done.
"f:/dynamic_mesh/dynamic_mesh"
Opening library "libudf"...
Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Could you please help me out understanding what the error is about.
thanks
sam
Originally Posted by STK
;113259
samcfd is offline   Reply With Quote
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 05:02
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Dynamic Mesh problem Paul_321 FLUENT 11 August 11, 2009 11:32
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 21:17
Dynamic mesh problem Sampath FLUENT 1 October 13, 2004 06:44
