Periodic boundary condition - pipe flow -setting up heat transfer |
December 4, 2012, 03:36 |
Chris Dorer
Rep Power: 15 |
Hi there,
i am trying to run a periodic flow of a part of a pipe. I chose the eights part of a pipe and set up the inlet and outlet as translational periodic and the long surfaces as rotational periodic and the curved surface as wall. After i defined the mass flow rate in translational direction and solved the flow and turbulence with the k-w SST model. It worked quite well and the pressure drop in the pipe part is nearly the same as calculated in the empirical model of Pethukov (<1% for Re=37000). So after solving the flow and turbulence i turned off solution for flow and turbulence and turned on energy for the heat transfer solution. Now i get the the message: "turbulent viscosity limited to viscosity ratio of 100000 in 35400 cells" "divergence detected in amg solver: temperature -> increasing relaxation sweeps!" "primitive error at node 0: floating point exception" "error: floating point exception" "error object: #f" What can i do now? thanky guys |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Pipe Flow Heat Transfer | Saima | CFX | 5 | January 30, 2011 16:41 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 08:40 |
