Uds_flux
Old   December 13, 2012, 01:37
Default Uds_flux
Indrajit
IndrajitW is on a distinguished road
Hi all,
I am using a UDS transport equation but instead of the conventional mass flow rate flux term (rho*Phi*U) I need a phi*U term. For that I tried to define the flux term by UDS_FLUX macro, but I suspect perhaps it takes the flux normal to the boundary (wall for example). I need the flux in u direction which is parallel to the wall.
Please help.
Indrajit
IndrajitW is offline   Reply With Quote
Old   December 13, 2012, 02:26
Yang Xiaoguang
legendyxg is on a distinguished road
Hi Indra,
Maybe you can first get the facet area vector A via F_AREA(A,f,t), and then multiply the component of A normal to the u direction, i.e. A[1] if u direction is the x direction, by U.
legendyxg is offline   Reply With Quote
Old   December 14, 2012, 01:51
Indrajit
Thanks a lot Yang!! I will see if that helps
