January 7, 2013, 15:18 |
Fluent batch command for unsteady
Rep Power: 13 |
Hi!
Where can I find the command for the batch script? I have worked Fluent with my PC in GUI mode, thus, I am not familiar with the linux using batch mode. I tried to find manual for the command, however, I just can find simple example for the batch file. I am not familiar with strange symbols in the command such as, "<",">" , #PBS. I just using the example file to make run my file. I can run the steady case with batch mode. but unsteady case is not working What I changed from the batch file is solve/iterate to solve/dti It does not work. I tried the case file that worked in GUI mode. especially, I want to use non-iterative time advancement However, I do not even know the command for this option. Please help me to learn and understand batch script. Thanks Last edited by taekyu8; January 28, 2013 at 11:11. Reason: Could you delete this posting. I found out what I needed. Nodody replied on my post. |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Save images using Fluent in batch processing mode | dixitked | FLUENT | 8 | August 29, 2019 12:25 |
problem with fluent in batch mode | Pat | FLUENT | 2 | February 13, 2003 13:14 |
Run Fluent in batch mode | Shengping LUO | FLUENT | 2 | October 24, 2000 05:42 |
Batch File fo Fluent & Fieldview | Oliver | FLUENT | 0 | July 14, 2000 13:12 |
