Porous Jump for 2D Modeling
Old   January 14, 2013, 03:35
Default Porous Jump for 2D Modeling
THC
THC
THC is on a distinguished road
Dear all, I need some helps in creating a porous jump for a 2D model using FLUENT (ANSYS 14).
The model contains two faces: The upper face and bottom face (two rectangles) connected by a membrane (the membrane is an edge). I’m trying to simulate a flow through the membrane. I’m supposed to put the boundary condition of the membrane edge as porous jump. However, in FLUENT, the option “porous jump” is not available for this membrane edge. “Porous Jump” option is only available for the upper and bottom face. Based on my understanding, porous jump should be attached to edge and not to face. Am I wrong?
[Btw, I got an error message when trying to mesh the geometry: “PlugIn Error: No valid bodies found for 2D Analysis in part Part”, but I still manage to mesh it. Not sure if this is the problem?]
Another option is to create the membrane as a face with a certain thickness (say 1mm). But won’t this be a conflict with the input “Porous Medium Thickness” in the Dialog Box if these two values were different?
Thanks in advance!
THC is offline   Reply With Quote
porous jump
[ICEM] How can I define different zones in ICEM? llrr ANSYS Meshing & Geometry 14 February 12, 2017 13:44
[Commercial meshers] Porous Jump creation problem mulfal OpenFOAM Meshing & Mesh Conversion 4 December 9, 2013 11:59
Effects of mesh on results of FLUENT modeling using porous jump model newcomer FLUENT 1 June 25, 2012 01:13
Porous Jump Naresh FLUENT 0 April 25, 2007 15:36
Testing the integrity of POROUS media and por jump Azman FLUENT 0 July 31, 2006 11:11
