solidification and melting with VOF: how to sink solid PCM as it melts?
Like Tree24Likes
Old   August 8, 2015, 00:15
Arash Silver
arashsilver is on a distinguished road
Originally Posted by B.Hamada View Post
Thank you
But i have a question, i have two data one for solid phase and the other for the liquid phase, for example there is a liquid density and a solid density, the same for the Specific heat capacity, and the Thermal conductivity.
but in fluent, I can enter the parameters of a single-phase.
please, what can i do?
Oh, I'm suffering from exactly the same problem and I'm a newbie :-(
Did you find any solution to this? If so, please help me.
Regards
Arash
arashsilver is offline   Reply With Quote
Old   November 15, 2015, 11:02
Parsa
parsa is on a distinguished road
Regards
Arash
This is my question as well; as I am fairly new user of ANSYS Fluent. Does anybody can help?
Thanks in advance,
Parsa
parsa is offline   Reply With Quote
Old   April 11, 2016, 14:59
Rami
rzyz is on a distinguished road
Originally Posted by HamidIran View Post
Hi Hamada,
Depending on the melting temperature that you define for your PCM in Materials tabs and the initial temperature you set in the "Solution Initialization" tab, the initial state of PCM is automatically determined. For example, if your PCM melting point is 309<Tm<311, if you set the initial temperature to 308, the PCM will start from solid phase. If your initial temperature is 312 the initial PCM phase will be liquid, and if the initial PCM temperature is 310, the initial volume fraction of liquid phase will be 0.5.
I hope this helps.
Hamid
Do you know the reason for usual selection of an initial temperature of the PCM higher than the liquid temperature in the case of fully liquid or lower than the solidus temperature in the case of the fully solidified rather than using the exact PCM solidus and liquidus values in FLUENT? As I know the FLUENT considers the liquid fraction = 1 for the liquidus temp and 0 for the solidus temp. Is this just related to the accuracy of the results and just to ensure convergence?
rzyz is offline   Reply With Quote
Old   April 14, 2016, 07:06
Rami
Hi Hamada,
I hope this helps.
Hamid
Old   June 8, 2016, 03:02
Default solidfication & melting VOF function
  #25
vijay kumar
vijayknmodi is on a distinguished road
can any one have have the steps for melting of ice in ansys fluent .. please share the steps
vijayknmodi is offline   Reply With Quote
Old   September 16, 2016, 14:16
svk
vishu
svk is on a distinguished road
In order to give different thermal properties for solid and liquid phases. I think the following description may do the task.
If you take density not as a constant value but as a function of temperature (say piecewise linear function), you can set one value for below melting point (i.e. for solid) and one value for above.
svk is offline   Reply With Quote
Old   September 16, 2016, 14:17
svk
vishu
Thank you
Old   November 3, 2016, 21:59
Peter Aestas
aestas is on a distinguished road
Originally Posted by beer View Post
Hi zbc19910519
Sure. Just use a very strong force, which is velocity dependent. For example 1e10*(vx-1) if you want your velocity component in x-direction to be 1. Just remember to tell the solver the derivative of this equation (I think it is called Source Coefficient in Fluent), otherwise the source will blow up your calculation. The solver uses the derivative to include the force in the implicit part of the solver (see Patankar).
Cheers
Hi, beer.
I am trying to solve a similar problem,like ice melt.
In order to solve the move of solid, i try to add a gravity force source to the y momentum.
DEFINE_SOURCE(solid_source, cell, mix_th, dS, eqn)
real source;
cell_t c;
real x[ND_ND],r;
real m_lg,a,b;
Thread *pri_th, *sec_th;
pri_th = THREAD_SUB_THREAD(mix_th,0);
sec_th = THREAD_SUB_THREAD(mix_th,1);
m_lg = 0.0;
if (C_LIQF(cell,pri_th)==0)
m_lg = -9.8*C_R(cell,pri_th);
else
m_lg = 0;
dS[eqn] = 0;
return m_lg;
but still it did not move.
Can you help me?
aestas is offline   Reply With Quote
Old   November 4, 2016, 15:00
Default heat exchangers
  #29
m
mehradahmadi is on a distinguished road
Hi all, I want to do a project about Numerical simulation of heat exchangers with phase-change material with the help of Fluent.
For example, air from the inside of phase-change material between two parallel plates are passed, and We want more cool air to keep output As shown below:
What options should be activated and how that process performed?Please please help me , If it is possible….
thank you.
mehradahmadi is offline   Reply With Quote
Old   November 23, 2017, 20:10
HamidIran is on a distinguished road
Thank you
Hamada,
You need to specify temperature dependent properties for your PCM by using a UDF. I suggest you consult UDF manual for "property" related UDFs.
Hamid
HamidIran is offline   Reply With Quote
Old   November 23, 2017, 20:18
Rami,
If you set the initial temperature exactly equal to the liquidus temperature a very small temperature fluctuation due to round-off errors or any other numerical swing may result in dramatic change in the source terms related to the phase change and creates numerical instabilities. That's the only reason.
Good Luck,
Hamid
mroue likes this.
Old   October 22, 2019, 17:34
Djamila
djamila77 is on a distinguished road
Originally Posted by msaeedsadeghi View Post
I have done that. It's easy, you may have done a great mistake.
hi there;
<i'm new in the domain
can you help me
thank you
djamila77 is offline   Reply With Quote
Old   November 15, 2019, 06:27
Shoonya is on a distinguished road
A large mushy zone constant enforces the velocity in solid phase to go to zero (or to pull velocity). If you set it to zero the solid phase will move with a velocity obtained from the solution of the N-S equations. However, it will deform like a liquid.
That is useful.... Thanks
Shoonya is offline   Reply With Quote
vof phase change
PCM melting inside the Al cavity shoxan FLUENT 1 August 9, 2018 02:12
VOF with melting of Phase change materials sakil2k3 FLUENT 3 March 17, 2015 15:26
How can I make the solid PCM to sink to the bottom as it melts? Lim FLUENT 6 December 22, 2014 02:29
Laser vof melting solidification injection Michael FLUENT 0 February 20, 2007 21:28
vof + solidification melting James FLUENT 0 November 29, 2002 10:56
