Pressure based and Density based Solver
Old   January 28, 2013, 11:05
Default Pressure based and Density based Solver
taekyu8 is on a distinguished road
Hi.
I have run transient gas expansion problem. Initially I opened a cap of pressurized vessel.
When I ran with 7 MPa pressure. pressure-based solver does not work, only density-based solver works
However, when I lowered the pressure to 0.5 MPa, pressure-based solver also works.
I know the the pressure-based approach was developed for low-speed incompressible flows, while the density-based approach was mainly used for high-speed compressible flows. However, recently both methods have been extended and reformulated to solve and operate for a wide range of flow conditions beyond their traditional or original intent.
Both 7 MPa case and 0.5 MPa case have chocked flow at the opening. Therefore, I thought if the 0.5 MPa case works with pressure-based solver, the 7 MPa case should works too.
Does anyone explain what cause this problem?
Thanks
taekyu8 is offline   Reply With Quote
Pressure based and Density based Solver Xobile Main CFD Forum 39 August 19, 2020 06:04
Using Density Gradient C_R_G(c,t), Pressure Based Solver Anirudh_Deodhar Fluent UDF and Scheme Programming 1 October 25, 2013 05:43
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 15:59
Pressure gradient in UDF for density based solver matzb FLUENT 0 February 22, 2010 06:34
Pressure based and Density based Solver Xobile Siemens 1 November 30, 2004 21:13
