advection-diffusion equation
Like Tree3Likes
  • 1 Post By tseo
  • 2 Post By Ivan
Old   August 22, 2003, 19:55
Default advection-diffusion equation
tseo
Hi, I am going to solve coupled navier-stokes and advection-diffusion equation. Is it possible to simulate these equations in FLUENT? If so, please tell me how to imply FLUENT to coupled navier-stokes and advection-diffusion equation. Thanks in advance.
Old   August 23, 2003, 04:39
Default Re: advection-diffusion equation
Greg Perkins
By advection-diffusion equation I assume you mean the transport of a scalar due to the flow.
Yes this is possible to do in FLUENT.
Depending on what your scalar is you may be able to use internal standard FLUENT models (eg. species transport) otherwise you can write some C code to define the diffusion term and source term of the scalar when coupled with the flow equations.
Greg
Old   August 25, 2003, 04:22
Ivan
YES!! you can simulate the advection-diffusion process. I had tried some convection-diffusion for gas-gas and gas-porous media. the result quite good.... but still need to figure out some thing for gas-liquid system....
what version of the FLUENT u used?? FLUNET v6 got some glitch when calculating the concentration, the latest version corrected this glitch already.
best luck!!
tyw
Old   August 27, 2003, 19:16
tseo
Thank you for your comments. I am trying to simulate the concentration (advection-diffusion equation) coupled with flow (navier-stokes equation). Do I need to write udf program or to use internal standard fluent model? Thank you in advance.
Old   August 29, 2003, 02:02
Ivan
Currently i am using the internal code. do u have any similiar experiment result with u problme?? if u have then you may try to simulate the experiment and compare. if the result is quite good, then i believe no need to use a udf...
best luck,
Ivan
Old   August 29, 2003, 05:15
tseo
Thank you for your comments. No, we don't have experimental data. We are going to simulate the concentration of drug in the blood flow. Thus which part of Fluent manual do I have to read? Thank you in advance.
Abdulrajak Buradi likes this.
Old   September 1, 2003, 23:33
Ivan
under the species transport section.
good luck for u simulation.
somy1 and Abdulrajak Buradi like this.
Old   October 24, 2011, 04:24
Thumbs up
somayyeh m
somy1 is on a distinguished road
Originally Posted by Ivan
;107744
thank u very much Ivan.
somy1 is offline   Reply With Quote
Old   February 20, 2013, 07:36
Default simple advection diffusion models
Hansjoerg Seybold
hansjoerg is on a distinguished road
I'd like to come back to the question of solving simple scalar time dependent advection-diffusion equation in Fluent without energy coupling for a static (frozen flow field) e.g. contamination concentration
http://http://en.wikipedia.org/wiki/...usion_equation
where c is the concentration and v the fluid velocity
Fluent offers transport models at 3 places
1. Thermal models
2. scalar transport models (UDS)
3. Transport & Reaction
I understand the basic concepts in the Theory Guide but i get confused with all the different options in the menus and options.
Could anyone guide me which model to choose and how to define the different transport parameters.
Thanks a lot in advance.
hansjoerg is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Advection equation.... CFD Question Main CFD Forum 4 May 12, 2005 12:00
Diffusion Equation izardy amiruddin Main CFD Forum 2 July 4, 2002 08:14
