Dividing one interior in two
Old   March 1, 2013, 22:45
Default Dividing one interior in two
starter
sihaqqi is on a distinguished road
Dear All
I have these two pipes connected at 90 degrees with a mitre joint. I have defined 4 regions in meshing, inlet, outlet, upstream (vertical run) and downstream ( horizontal +X) as shown in attached file. When I open Meshed file in Fluent, an interior zone is generated for the complete geometry. I want this interior to be divided in two, one for vertical and other for horizontal so I can monitor velocity and pressure profiles separately for both runs. Can anyone advise how I can make this division.
Thanks
sihaqqi is offline   Reply With Quote
Old   March 4, 2013, 17:43
sp
chaosh is on a distinguished road
The easiest way is to create two zones in your solid model before you mesh and export. (if you are using Workbench for this, just cut your model where you want and when you mesh and export, set a named selection for each zone). Remember to combine your solids into one 'Part' before meshing.
You can do this in Fluent as well, but you will have to go to Mesh>Separate..I suggest going through Fluent tutorials on how to merge/separate bodies. It should be in "Modifying the mesh" section.
Good luck
chaosh is offline   Reply With Quote
Old   March 4, 2013, 18:38
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
in icem you have one all your block called fluid.
if you go back to icem, name the vertical block vetical and horizontal horizontale, you will have your two interior. it's always better to think about that when meshing.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
fluent, interior division in two
[ICEM] Question about fluid domain dividing lnk ANSYS Meshing & Geometry 0 July 19, 2012 14:19
Porosity profile, dividing a zone, or getting zone location from zone khoopes FLUENT 0 June 2, 2012 19:39
Error dividing surfaceScalarFields using fvc::interpolate(volScalarField) Canesin OpenFOAM Programming & Development 1 September 27, 2010 19:05
natural convection in a square enclosure with a partial dividing wall sandeepmishra FLUENT 3 May 6, 2000 04:25
natural convection in a square enclosure with a partial dividing wall sandeep Main CFD Forum 0 April 30, 2000 00:38
