Flow through a perforated drum
Old   March 8, 2013, 06:42
Default Flow through a perforated drum
Martin Cermak
mcermak is on a distinguished road
I'm trying to figure out the way how to model a flow through a perforated rotating drum in the simplest way. The image below should clarify the situation I am talking about.
The main domain of interest of the simulation i'm trying to do lies upstream from the inlet marked in the figure above, but because the drum rotation influences the flow quite significantly i might have to include the drum in the simulation.
The diameter of the drum is approx 0.9m, the length is 0.8m and it is perforated by 6mm holes. Meshing the drum would mean quite a lot of cells, so I was thinking about some alternative approach, that does not necessarily have to be 100% accurate. The outcome of this should be only a qualitative assessment of how the rotating perforated drum influences the channel flow.
My first idea was to use a rotating porous media zone concept, but I haven't reached any promising approach. Is there, in general, any way how to model a permeable rotating wall/zone or is this thought absolutely non reasonable?
Any suggestions are welcomed!
Thanks in advance,
Martin
mcermak is offline   Reply With Quote
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 16:10
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 08:36
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
