chemical reaction problem
Old   July 5, 2001, 10:16
Default chemical reaction problem
Benoit
Hi ! I'm student in France and I TRY to use Fluent… I'd like to simulate a quite complex reaction. So, I've to use an UDF for generating sources. To understand how to proceed I try with a simple reaction just below :
A + B -> C with r (kg/m3.s) = 1017 exp (-105/RT) . CA.CB
I've compared the results obtained with the reactions panel and those obtained with UDFs. In order to obtain the same results I've to multiply the preexponential factor A by 100 (so 1019) in my UDFs model.
Can anybody tell me the reason? I'm thanking you a lot for any suggestion.
Old   July 5, 2001, 13:12
Default Re: chemical reaction problem
Paul Izabel
I've had similar problems with chemical reactions and the Arrhenius model. Might be a problem with your units - check them. good luck, Paul
Old   March 14, 2013, 14:56
Default arrhenius constants units
hossam ali
hossam_ali is on a distinguished road
hi i want to know the units of arrhenius constants applied in fluent
thanks
hossam_ali is offline   Reply With Quote
problem about porous media and surface reaction Jeff Lee FLUENT 3 November 24, 2011 13:46
Problem implementing DETAILED REACTION MECHANISM Phil FLUENT 0 May 5, 2007 11:38
Simpler Chemical Reaction Problem Sam Siemens 7 February 7, 2006 09:28
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
UDF : Chemical Reaction in Catalytic Converter adhimac FLUENT 1 March 27, 2001 14:04
