how to correct backflow in modelling cylinder?
Old   March 22, 2013, 14:29
Question how to correct backflow in modelling cylinder?
amin masumi
aminepoxnet is on a distinguished road
hi dear,
I have a cylinder that have backflow after modelling, I extended my inlet and outlet but there is backflow yet.
please help me how can I correct this backflow? thanks a lot
aminepoxnet is offline   Reply With Quote
Old   March 22, 2013, 16:40
Wagner Queiroz Barros
wagnerqb is on a distinguished road
Send a message via Skype™ to wagnerqb
It can be a model problem, a numerical problem or a mesh problem.
Please could you describe better your simulation, like reynolds number, fluid proprieties, and geometry?
wagnerqb is offline   Reply With Quote
Old   March 23, 2013, 12:13
amin masumi
thank you for your attention,
that's a simple grid model, a simple cylinder with an inlet and outlet, but I want to model two fluids at once, one at the right hand of the piston and the other at the left hand of piston, oil as the first fluid at the right and air at the right hand as the second fluid.
I have some experiences in modeling cylinders and a piston pump, but I want to ask about any information or ebook ... to help me know further about backflow, what would cause backflow and how to correct backflow.
this cylinder modelling that I described at first is so important for me, please try to help me, thanks a lot.
Old   March 23, 2013, 13:01
Backflow is not a real problem in simulations, depend on the phenomena involved. Example if there is a circulation zone at the outlet, there will be a a reverse flow in some cells at outlet. A way to fix this is increase de outflow lenght, but it is no necessary if you accept the backflow in this area.
I think there is a recirculation zone near to your outflow.
Old   March 23, 2013, 13:32
amin masumi
my dear,
but when I display velocity vector results, although there are perfect results that are expected but all the vectors are reversed, and no vector is displayed so that passing out of the boundary.
what would cause the problem?
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Cylinder moving in fluid,Solution diverging arun7328 STAR-CCM+ 5 February 27, 2013 14:28
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
how to ensure that your modelling is correct rvndr Main CFD Forum 7 March 1, 2004 12:21
