animation in fluent
Old   August 18, 2014, 03:26
Default animation in fluent
arindamsantra7 is on a distinguished road
I have done the simulation of fluid flow in nozzle & also get result & different contours using fluent. Now I want to know that how to make a animation video of fluid flow in nozzle using Ansys fluent 14.?
arindamsantra7 is offline   Reply With Quote
Old   August 19, 2014, 09:02
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
You need to collect the data for the video during the calculation. Go to "Solution -> Calculation Activities -> Solution Animation" and hit the "Create/Edit" button. The rest should be self explanatory. Let's say, you take a picture every time step. Then, run the simulation for a certain amount of time steps. After that go to "Results -> Graphics and Animations -> Animations -> Solution Animation Playback" and hit "Setup" button.
If you have problems just post again.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   August 20, 2014, 01:38
ringtail is on a distinguished road
There is a simpler way if you just want an animation for pressure contour or velocity contour and so on.
Execute "hardcopy" for the contour every time step and save it into a picture. Then compress all the pictures into a "gif" file. Now, you get a simple animation.
ringtail is offline   Reply With Quote
Old   August 20, 2014, 02:35
Default how to save the animation in mpeg file
I have done the animation in ansys fluent 14.0 but I am not able to save the animation file in MPEG file format from where I can able to play the animation in vlc media player.
Old   August 20, 2014, 02:37
Philipp
What is the problem?
Old   August 20, 2014, 02:42
I want to save the animation file in video format & want to play the animation file in vlc media file
Old   August 20, 2014, 03:29
Philipp
You are pretty tight-lipped. It's hard to help. Where exactly in the production of the video clip do you encounter the problems?!
Animation in Fluent jackr84 FLUENT 4 November 19, 2013 02:46
FLUENT animation axis labels taylorfe FLUENT 2 June 1, 2012 17:39
Fluent 12 Animation sahm ANSYS 2 November 5, 2010 17:45
animation in fluent doki FLUENT 0 June 10, 2010 08:04
ANIMATION with Fluent Luca FLUENT 0 June 6, 2005 04:13
