July 17, 2003, 00:05 |
What's wrong? Non-conform mesh problem!!!
I have set all non-conform interface BC and could have a result.But when I left the fluent solver then start fluent again, I could read the .cas file that I saved before but when it "bulding grid" the error message appeared on control window as below:
Error: %si-create-grid-interface: wta(int) Error Object: (sb1-id . 6) . . . . . Error: inquire-adjacent-threads: wrong type argument[1] (thread) Error Object: 0 . . Then I could't read .dat file that I saved before. someone know what's wrong? Please give me a hand Thanks all |
March 31, 2013, 15:00 |
fluent error
Ravi Jogi
Rep Power: 13 |
I have same problem but could not get solution.
I have meshed centrifugal pump model in hypermesh 9. then meshed file is exported to gambit for boundary condition. And then simulated in fluent. Whole simulation completes. Then I closed fluent. Then again opened fluent and read case and data file. Now fluent shows error Error: %si-create-grid-interface: wta(int) Error Object: (sb1-id . 6) I can not understand where the problem is. Is it in meshing or grid interface? Waiting for the reply |
udf error | srihari | FLUENT | 1 | October 31, 2016 14:18 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Problem with Output to .cfx5 mesh | Ben | CFX | 4 | January 24, 2008 17:47 |
