June 30, 2018, 10:27 |
Import CSV volumetric heat
Novalis
Rep Power: 8 |
I need to import a CSV volumetric heating values (point based) as a heat source for my analysis. Ideally to be interpolated into selected zones of a thermal hydraulic analysis (only applied at solids zones).
Which would be the easy way? Easy meaning I have no knowledge of UDF programming... thanks |
July 1, 2018, 11:36 |
Lucky
Rep Power: 66 |
Try a cell zone PROFILE. You have to do some work to convert your csv into the format.
July 1, 2018, 11:43 |
Novalis
Rep Power: 8 |
Can you give me some hint about the needed formatting in the CSV? I need to import & interpolate a volumetric heat source, which values varies on the 3d
volumetric heat source | wanghong | FLUENT | 2 | February 1, 2018 09:38 |
Volumetric Heat generation in cylinder with natural convection conjugate heat transfe | sandymech | OpenFOAM Running, Solving & CFD | 0 | August 9, 2017 18:36 |
External file as input for volumetric heat source in solid (chtMultiRegionSimpleFoam) | pbnuclex | OpenFOAM Pre-Processing | 0 | June 1, 2016 03:53 |
UDF Outputs dont match exactly for volumetric heat generation. | nvarma | Fluent UDF and Scheme Programming | 3 | May 23, 2016 17:41 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
