August 6, 2011, 12:14 |
TUI - Porous zone and energy source terms
Rep Power: 16 |
I am working on a problem that require modeling of a radiator. Since the flow structures are rather complex I need to start simple and work my way up in complexity.
Halfway through I need to activate an energy source term in a porous zone with a certain magnitude. I have tried looking for it in the manual and went through all the /define options. I have however been unable to find a command that can provide me with this option. With a direct interface it would be: Cell Zone Conditions -> porous (name) -> edit -> activate source terms -> Energy (W/m3) -> One source (number of sources) -> constant Could somebody please inform if it is possible and how to approach it? Thanks |
July 26, 2012, 19:44 |
Negin Nazarian
Rep Power: 14 |
Hi
I almost have the same issue I cant access cell zones conditions with TUI have you figured it out? I would appreciate if you tell me. Cheers Neg |
April 25, 2013, 10:34 |
Sheng
Rep Power: 14 |
I get it sorted. Just try here: /define/boundary-condition/fluid (live) zone id/name [live] material-name [air], change current value? [no] then Specify source terms? [no] yes ... "live" is the name for my fluid zone. Regards, Sheng |
source terms problem-hybrid combustion | alanlove | Fluent UDF and Scheme Programming | 2 | November 15, 2019 07:31 |
source term for energy source from a wall surface | rahulsharma | FLUENT | 0 | February 1, 2010 02:00 |
How to specify energy source in a fluid zone? | abong | FLUENT | 0 | February 17, 2005 02:15 |
Temperature drop after porous zone | MN | FLUENT | 0 | December 10, 2003 12:28 |
How to define energy source? | Marie | FLUENT | 2 | September 19, 2002 05:27 |
