Error: Floating point error: overflow
Old   April 25, 2013, 02:40
Default Error: Floating point error: overflow
sezar is on a distinguished road
Hi everyone
I have a question
i am simulation two phase flow at fluent
air=primary phase----------water liquid=secondary phase
air velocity=10m/s &water velocity=1m/s
i am use the schiller naumann for drag
and slip velocity i am use manninen - et-al
but when i am run simulation This message is appear
((Error: Floating point error: overflow))
can some one help me ?
sezar is offline   Reply With Quote
Old   April 25, 2013, 04:25
OJ
oj.bulmer will become famous soon enough
Are you sure about the phases are not other way around, ie Water being primary and air being secondary?
OJ
oj.bulmer is offline   Reply With Quote
Old   April 25, 2013, 05:35
hi
i am sure
air carried water droplet toward filter
air= primary phase=i am sure
Old   April 25, 2013, 05:51
Paritosh Vasava
vasava will become famous soon enough
There can be several reasons for the floating point error. If your case is transient than try reducing the time step. A relatively bigger time-step can be the reason behind this error.
I hope you have fine mesh else that could also be another problem.
vasava is offline   Reply With Quote
problem in toposet Ahmed Khattab OpenFOAM Pre-Processing 27 March 3, 2023 21:12
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 00:37
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
