NIST real gas model can not converge
Old   May 6, 2013, 13:30
Default NIST real gas model can not converge
mayanyun is on a distinguished road
I am doing a simulation recently. With heat exchange and flow.
If I define the gas material parameters as constant such as density, it can be converged. First I simulate the flow case. Then I do the heat exchange. It is ok. But as the temperature change range is from 40K to 300K.
So I change to NIST real gas model. Then it can not converge.
mayanyun is offline   Reply With Quote
Old   May 6, 2013, 14:01
Default error message
Error: REFPROP_error (-51) from function: trnprp (viscosity)
[TRNPRP warning -51] one or more inputs to the thermal conductivity and viscosity correlations are out of range; will use ECS model; temperature > 1.5 x upper limit, T = 5000.0 K, Tmax = 1500.0 K
Old   March 24, 2014, 00:09
Exclamation nist real gas midel R134a
arun km
arun km is on a distinguished road
sir
i am doing a simulation of an ejector (vapor jet refrigeration system) with NIST real gas model.I am getting the same result that you have got earlier.Please share the remedy if you solved this problem recently.
Thanks in advance
arun km is offline   Reply With Quote
Old   June 29, 2016, 03:44
Malte Semmel
MalteSe94 is on a distinguished road
Has anyone found a solution on this topic already?
I am facing the same problem and am desperate for help.
Kind regards,
Malte
MalteSe94 is offline   Reply With Quote
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
Using real gas models in Fluent neville FLUENT 1 June 5, 2012 05:54
error message cuteapathy CFX 14 March 20, 2012 06:45
UDF error - FLUENT received fatal signal (ACCESS_VIOLATION) Eliasjal Fluent UDF and Scheme Programming 1 March 7, 2012 11:11
about the real gas in Numeca redboy Fidelity CFD 2 March 4, 2003 07:57
